B Field in Semicircle Conductor
The discussion focuses on calculating the magnetic flux density (B-Field) at the center of a semicircular conductor shell with radius A carrying a total current X. The user proposes using the formula for the magnetic field due to a long wire, specifically B = (μ * I) / (2 * π * r), and intends to integrate the differential contributions (dB) from 0 to π. However, the user encounters an issue where the integral results in zero, indicating a misunderstanding in the setup of the integral, particularly in expressing dI correctly.
  • Understanding of magnetic fields and the Biot-Savart Law
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of cylindrical coordinates and their application in electromagnetism
  • Basic concepts of current distribution in conductors
  • Review the Biot-Savart Law for calculating magnetic fields from current distributions
  • Study integration techniques for polar coordinates in electromagnetism
  • Learn how to express differential current elements (dI) in terms of angular coordinates
  • Examine examples of magnetic field calculations for various conductor shapes
Students and professionals in physics and electrical engineering, particularly those studying electromagnetism and magnetic field calculations in conductive materials.
Telcron
Basically there is conductor shell which is in the shape of a semicircle. It extends to infinity. (Think of this as like half of a cylindrical conductor shell). The radius of this shell is A, and it carries a total current of X. The shell extends infinitely into the page. What is B-Field (Magnetic Flux Density) at the center of this conductor? I attached image for clarity.
I think that this problem should be easy to solve. Basically I find the B field due to a long wire of some current, and then change this to make it dB which I would integrate from 0 to pi to find the total B - Field as the superposition of all of the dB elements. Does this sound like the right approach? I know that the field due to a wire is ([tex]\mu[/tex]* I)/(2*[tex]\pi[/tex]*r) where r is the distance from the wire. For dB, this should be ([tex]\mu[/tex]* dI)/(2*[tex]\pi[/tex]*r). I am not quite sure how to set up this integral as I am not quite sure on how to express dI. Any suggestions?
Sorry for my bad English I do not speak it natively.
Also I am sorry I am not good at the text formatting for the equation. The mu and the pi should not be superscript.
So I think I have made progress. I have dB = ([tex]mu[/tex]dI) / (2[tex]pi[/tex]A) and I have dI as Id[tex]phi[/tex]/[tex]pi[/tex]. The B-Field from each dB is in the [tex]\phi[/tex] directions, and as you integrate dB from 0 to [tex]\pi[/tex] to get the whole B-Field the final field will point to the left because everything else will cancel out. The problem is when I take this integral I get 0. Any help? Please.
  • · Replies 23 ·
  • · Replies 40 ·
