Why is My Potted Christmas Tree Drying Out and Losing Needles?
  • Thread starter Thread starter NeoDevin
    Christmas Tree
The discussion revolves around the care and maintenance of a potted Norfolk Pine that is drying out and losing needles. Participants explore various factors that could contribute to the tree's condition, including watering practices, root health, environmental conditions, and fertilization. The conversation includes both theoretical and practical aspects of keeping such a tree healthy indoors during winter.
  • Experimental/applied
  • Some participants suggest that the tree may be root bound, while others question whether it is receiving too much or too little water.
  • There is a discussion about the importance of dormancy for evergreens, with some arguing that indoor conditions may not provide the necessary temperature changes.
  • One participant mentions the need for proper root structure when potting and the potential use of rooting hormone and specific fertilizers.
  • Concerns are raised about the tree's exposure to heat sources indoors and the need for high humidity levels, particularly during winter heating.
  • Some participants express skepticism about the tree's chances of survival, noting that if the needles are already dry and falling off, it may be too late to save it.
  • There are suggestions about how to keep the tree outdoors during cold weather, including building a protective structure from snow, while also considering the risks of freezing temperatures.
  • One participant shares their experience with keeping Norfolk Pines and emphasizes the importance of watering and humidity management.
  • Another participant reflects on their past failures with similar trees, indicating the challenges of maintaining them as houseplants.
Participants express a range of views on the care of the Norfolk Pine, with no clear consensus on the best approach. There are competing opinions on the necessity of bringing the tree indoors versus keeping it outside, as well as differing perspectives on watering and fertilization practices.
Some participants note the limitations of their knowledge regarding specific care techniques for Norfolk Pines, including the effects of environmental factors and the challenges of maintaining humidity indoors.
Individuals interested in indoor gardening, particularly those caring for Norfolk Pines or similar evergreen species, may find this discussion relevant.
NeoDevin
I have a potted tree that I bought last year, it was to be my Christmas tree for many years to come. Unfortunately it seems to be drying and the needles are falling off.
Is this because it is root bound? Not getting enough water (I doubt this one)? Too much water? Not enough fertilizer? Too much fertilizer? Anybody?
Biology news on Phys.org
So it has been ok for 11 months?
What kind of tree?
Where have you been keeping it? Evergreens are notoriously difficult to keep indoors no matter how much sun and feeding.
Also, they need to have periods of dormancy. That is the number one reason why they die when brought indoors. They need the temperature changes experienced outdoors.
Also, when you potted it, did it have any root structure to speak of? If it didn't you should have carefully peeled some bark away and potted with some rooting hormone and 10-52-10. If there are no roots, there is no way the tree can feed itself.
The feeding in and of itself is tough and easy to do wrong.
No matter what, if the needles are dry and falling off, it's a goner. There's nothing you can do. The only thing you can do is to learn from this tree and apply that to the next one.
Yes, it was fine indoors last winter, and was out on my balcony all last summer. This winter when I brought it in it started drying up.
FredGarvin said:
What kind of tree?
It is a `Norfolk Pine' according to the tag that came with it.
It was outside on the balcony all summer. Once the temperatures started dropping below freezing I brought it in.
So I should have left it outside? I didn't want the roots to freeze, so I brought it in.
It had decent roots when I bought it.
What type of fertilizer should I be using, how often?
Not all the needles are dried up yet. It's drying from the bottom to the top.
Thanks for the advice. I attached a picture to the OP, it's still pending approval.
It didn't look like it was beyond salvation. We were always told that it should not be kept near batteries or any other place where there is too much heat. In nature pine requires a damp and shadowy place. Outdoors probably is better in that respect. However, since it is in a pot I would avoid freezing it completely.
Outdoors is currently snowing. Any advice on how to keep it outdoors without it freezing completely?
Do we have a financial constraint here? My engineering side would go for the extravaganza.
Ok, if the temperature is permanently below 0 C then there could be complications but I don't think occasional snowing hurts. Besides if there is a lot of snow you could build a little iglu for the pot. Temperature below (maybe 20cm?) snow is near 0 C. We planted our christmas tree to the ground and temperatures in the winter occasionally reach -30 C and it's still alive.
You were wise to bring it indoors. Its not a normal pine, its very tender. And where it lives naturally never freezes. If it gets frozen it will die. You need to water it when the top inch or so feels dry, and never let it sit in water. Feed it only when it shows signs of growth and use regular house plant fertilizer,not pine tree fertilizer.
The problem I have had with them is keeping the relative humidity high around the plant. They thrive on high humidity{50%}, and once the home heat is turned on, without additional humidity, the branches dry out very quickly. I ran a portable humidifier right next to mine, it seemed to help.
If you haven't re-potted it, you probably should. Go ahead and remove the dead branches, they will not come back.
i killed one of these several years ago. good luck.
That's the most alive I've ever seen one of those. I'm guessing they are not that easy to keep alive as a houseplant since I've never seen anyone successful with them.
Unfortunately finances (and maybe building codes?) don't allow for the construction of a full greenhouse on my balcony, though that would be awesome.
Here in Edmonton we routinely get entire weeks below -30 C. For now it is still warming above 0 C during the days, but pretty soon it won't be.
I re-potted it shortly after I purchased it. I'll see if I have any larger pots. If I don't, I'll have to try to find one to buy (won't be easy this time of year).
  • · Replies 67 ·
17K
  • · Replies 20 ·
13K
  • · Replies 21 ·
  • · Replies 31 ·
