Calculate Speed: 10m in 15s | Is My Answer Correct?
  • Thread starter Thread starter BUTTER-BENZ
The discussion revolves around calculating speed using the formula speed = distance/time, specifically for a scenario where a distance of 10 meters is traveled in 15 seconds. Participants are examining the correctness of the calculated speed.
  • Mathematical reasoning, Assumption checking
  • Participants are attempting to confirm the calculation of speed as 0.666667 m/s and are questioning whether this value is accurate based on the formula provided. There are also discussions about the importance of units in the calculation.
Some participants have affirmed the original calculation, suggesting that the answer is correct while emphasizing the need to consider units in the computation. Multiple interpretations of the calculation method are being explored, but there is no explicit consensus on the final answer.
Participants are working within the constraints of a homework problem, focusing on verifying calculations rather than deriving new methods or solutions.
BUTTER-BENZ
Is my answer correct??
calculate using this formula
speed = distance
_______
time
my first answer is :
travelled 10meters in 15 seconds = .666667 m/s
is this correct?
or would it be..
.666667 = 10
___
distance
_______
time ***
__
15 ***
speed = distance
_______
time
is this correct?
or would it be..
.666667 = 10
___
"travelled 10meters in 15 seconds = .666667 m/s" is correct. Just look at the units, and carry them along in your calculation. 10m/15s = 0.67m/s -- do the math on the units as well as the numbers, and use that to check that you've done the math correctly.
speed = distance
_______
time
is this correct?
correct
marlon
  • · Replies 32 ·
  • · Replies 17 ·
  • · Replies 26 ·
