Time needed for a transverse wave to propagate on a string
The problem involves a string divided into three segments with varying mass per unit length, and the task is to express the time taken for a transverse wave to propagate along the string in terms of its length, mass per unit length, and tension. The context is rooted in wave mechanics and properties of strings under tension.
  • Participants discuss the relationship between wave velocity and time, questioning the original poster's calculations and unit consistency. There is an exploration of how to correctly express time based on the velocities of the segments and the overall length of the string.
The discussion is active, with participants providing feedback on the original poster's approach and calculations. Some participants are exploring alternative methods to calculate the total time by considering individual segment times. There is no explicit consensus yet on the correct formulation.
Participants note potential confusion regarding unit consistency and the implications of wave speed on time calculations. The original poster is required to use specific variables without numerical values, which may limit the clarity of their expressions.
spaghed87
Consider a string of total length L, made up of three segments of equal length. The mass per unit length of the first segment is mu, that of the second is 2*mu, and that of the third mu/4. The third segment is tied to a wall, and the string is stretched by a force of magnitude T_s applied to the first segment; T_s is much greater than the total weight of the string.
Express the time t in terms of L, mu, and T_s. I must use those variables for this answer, no values were given for those variables so they must be included in the answer.
Velocity=sqrt(T_s/mu) -velocity of string
where, T_s is the tension of the string and mu is its linear denisty. mu=mass/length
My answer
time=((1+(1/sqrt(2))+2)*sqrt(T_s/mu))/(L/3)
since, time=v/m ==> m/s/m = seconds right? Edit: = 1/seconds
How I got that:
By pulling out the number multiplied by mu from the sqaure root I get:
The first segment is a velocity of 1*sqrt(T_s/mu)
The second segment is a velocity of 1/sqrt(2)*sqrt(T_s/mu)
The third segment is a velocity of 2*sqrt(T_s/mu)
Add those velocities toegther. Then to get the time you can just divide the velocity by the length of the string that is divided into three equal segments. So, dividing by (L/3) will give the answer. Anyone see what is wrong with my answer?
spaghed87 said:
... time=v/m ==> m/s/m = seconds right?
Well, no, those units would be 1/seconds or seconds-1, so something is wrong.
Your equation says that the faster the wave, the longer it would take, which is wrong intuitively. Faster waves should take less time to travel along the string.
I was thinking I had 1/s for time instead of s but I was having a brain fart. So, if I take the inverse of that equation it should be right then?
I ended up solving it differently by finding t_1, t_2, t_3, and then by adding all of the times for the time overall. Woot extra credit for me. Thanks for the help. Time for the test tomorrow. :smile:
  • · Replies 29 ·
  • · Replies 17 ·
  • · Replies 23 ·
