Inclined plane + Inclined force. Normal reaction force = ?
The discussion revolves around a physics problem involving an object on an inclined plane, where participants are tasked with determining the normal reaction force and the tension in a string. The object has a weight of 20N and is situated on a 30-degree incline, with an additional force applied at a 30-degree angle to the plane.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss resolving forces to find the tension and normal reaction force. There is an exploration of equilibrium conditions and the relationship between the forces acting on the object. Questions arise regarding the definition and calculation of the weight force and its role in the equilibrium equation.
Some participants have made progress in calculating the tension and are attempting to clarify the normal reaction force. There is an ongoing exploration of the vertical and horizontal components of the forces, with hints provided about using equilibrium conditions. Multiple interpretations of the forces involved are being discussed.
Participants are working under the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is a focus on understanding the relationships between the forces without providing complete solutions.
1337pHysiX
ok I'm desperate now lol n this is my first time on PF.
I've just had an exam and I'm sure i got this question wrong. But i'd like to know:
the normal reaction force and the tension/Force F.
The question is: There is this object that has a weight of 20N. It is on an inclined plane that is 30 degrees and it is held by a force 30 degrees to the plane. Determine the normal reaction force and the tension in the string.
Please give me as much relevant working as possible. Thank you for your help!
I have attached the diagram/question.
Show us what you've done and where you got stuck.
Hint: What are the conditions for equilibrium?
ok.
Resolving forces, I've figured that the tension/Force F = (20/3)*sqrt3 Newtons
now...i'm not sure wat the normal reaction force is. My friends are telling me that it's Normal Reaction + Tension - Weight Force = 0...but wat's the weight force then. lol
The only logic that i can conclude from this is that:
Normal Reaction force + all vertical components above plane = sum of all vertical components under plane, which kinda makes sense to me n is getting me the right answers right now.
well looking forward to ur reply =]
Good! The way you solved for this was to add up all horizontal force components (parallel to the plane) and set them equal to zero. Do the same for vertical force components (perpendicular to the plane) to find the normal force.
That's true, but you need to use the vertical components of those forces.
Sounds good to me.
