Cauchy sequences and sequences in general
In summary, a sequence converges if and only if it is a Cauchy sequence, although this may not hold true for more general metric spaces. In the real numbers or Rn, all Cauchy sequences converge, but in the set of rational numbers, Cauchy sequences do not necessarily converge. This is because Cauchy sequences may get close to each other without converging to a limit, as there may be a hole in the space where the limit should be. However, every metric space can be enlarged to include all potential limits of Cauchy sequences, resulting in all Cauchy sequences converging. This is how the real numbers are constructed from the rationals.
JG89
728
Is every sequence that converges a Cauchy sequence (in that for every e > 0, there is an integer N such that |a_n - a_m| < e whenever n,m > N)?
I think it is because if a sequence a_n converges to L, then you can mark off an open interval of any size about L such that this interval contains all of a_n except for at most a finite amount. So as the length of this open interval decreases then the distance between each point a_n gets closer and closer together. In fact maybe this open interval would be the epsilon neighborhood, because for two points a_n and a_m that are contained in this interval, we have |a_n - a_m| < e. Then within this epsilon neighborhood, we have points, a_j and a_p, where j,p > n, and j,p > m which are even closer to the limit, L, and again we have |a_j - a_p| < e, for an even smaller value of epsilon. We can obviously continue in this pattern, taking epsilon smaller and smaller as the integer n > N for the a_n gets larger and larger. And so in general, for large enough n and m, we have |a_n - a_m| < e.
Am I correct?
I have no idea what a metric space is. I've heard about it in Real Analysis, but I'm right now only learning theoretical calculus/basic analysis.
Don't worry about it too much... As far as you are probably concerned, yes Cauchy sequences are the same as convergent sequences.
Even in other metric spaces, convergent sequences are always Cauchy. This is just a two line proof using the triangle inequality:
If an converges to a, for all e there exists N such that n>N implies |a-an|<e/2 So if n,m>N|an - am| = |an - a + a - am| <= |a-an| + |a-am| < e/2 + e/2 = e Hence you have (an) is Cauchy
All convergent sequence are Cauchy. In the real numbers or Rn all Cauchy sequences converge. However, in the set, Q, of all rational numbers, Cauchy sequences do not necessarily converge. For example, the sequence 3, 3.1, 3.14, 3.141, 3.1415, 3.14159, 3.141592, ... (each term one more decimal place in the decimal expansion of [itex]\pi[/itex]) is a sequence of rational numbers since every term is a terminating decimal. It is Cauchy since, given any [itex]\epsilon> 0[/itex], there exist n such that [itex]10^n< \epsilon[/itex]. All terms in the sequence past the nth place are the same in the first n decimal places so their difference is less than [itex]10^n< \epsilon[/itex]. The sequence clearly converges to [itex]\pi[/itex] which is not a rational number and so does not converge in the rational numbers.
Thanks for the replies!
In a convergent sequence, all the entries eventually get close to some point L. In a cauchy sequence they eventually get close to each other.
as mentioned, by the triangle inequality, things that are close to L are almost as close to each other. but things that are getting close to each other may not be converging to any limit, because the space could have a hole in it where the limit should be.
just take any sequence of non zero numbers, like 1/n, that converges to zero. then remove zero from the space. the sequence is still cauchy but no longer convergent to an element of the smaller space.
conversely, every metric space can be enlarged by adding in all potential limits of cauchy sequences, so that afterwards all cauchy sequences do converge. that's how you make the real numbers out of the rationals. you take the ring of all cauchy sequences of rationals (that is a ring since sums and products of cauchy sequences are still cauchy), and mod out by the ideal of cauchy sequences that converge to zero.
the quotient ring is the reals.
1. What is a Cauchy sequence?
A Cauchy sequence is a sequence of numbers in which the terms get closer and closer together as the sequence progresses. In other words, for any given tolerance level, there is a point in the sequence beyond which all the terms are within that tolerance of each other.
2. How is a Cauchy sequence different from a convergent sequence?
A Cauchy sequence is a type of convergent sequence, but not all convergent sequences are Cauchy sequences. A Cauchy sequence focuses on the behavior of the terms in the sequence, while a convergent sequence focuses on the limit of the sequence.
3. Can a sequence be both Cauchy and not convergent?
Yes, a sequence can be both Cauchy and not convergent. This occurs when the sequence does not have a defined limit, but the terms still get closer and closer together as the sequence progresses.
4. What is the importance of Cauchy sequences in mathematics?
Cauchy sequences are important in mathematics because they provide a rigorous way to define the concept of convergence. They are also used in the construction of the real numbers, which are essential for many fields in mathematics such as analysis, calculus, and geometry.
5. Are Cauchy sequences only applicable to real numbers?
No, Cauchy sequences can be defined for any metric space, which includes real numbers, complex numbers, and other mathematical structures. However, they are most commonly used in the context of real numbers.
