Limit Problems with Calculus: Solution Attempt and Explanation
  • Thread starter Thread starter Diffy
    Limits
The discussion revolves around two limit problems involving calculus, specifically focusing on the behavior of summations as n approaches infinity. The first limit involves the expression (1^k + 2^k + ... + n^k) / n^(k+1), while the second limit concerns the summation 1/(n+1) + 1/(n+2) + ... + 1/2n.
  • The original poster attempts to analyze the limits by rewriting the terms and evaluating their behavior as n increases. They express uncertainty about their reasoning, suggesting that the limits might be zero. Other participants question this conclusion, noting that the results from numerical examples do not support it. There is a suggestion to use Excel for trend analysis, and one participant mentions the connection to Riemann sums and integrals.
The discussion is active, with participants exploring different interpretations of the limits. Some guidance has been offered regarding the relationship between the limits and Riemann sums, but there is no explicit consensus on the correct approach or final outcomes.
Participants are considering the implications of the variable k in the first limit and how it affects the result. There is also a mention of using numerical methods to verify assumptions, indicating a focus on empirical exploration alongside theoretical reasoning.
Diffy
Two questions
lim as n -> infinity
and
Definitions of limits, laws of exponents etc.
Well I think I have them both solved but it seems too easy therefore I think I did something wrong or am missing something.
I think they are both zero.
The first one you can rewrite the term in the limit as
(1^k)/(n^(k+1)) + ... + (n^k)/(n^(k+1))
If you take the limit as n goes to infinity of each of these, then they all go to zero.
I am not quite sure I can do this, or argue this that way, but it is the only thing that comes to mind.
For the second question, I do the same thing. Take the limit as n goes to infinity of each term. Since they all go to 0 the entire limit goes to zero.
Please let me know if my reasoning is correct.
One quick santiy check -- use Excel to do a few examples of each summation...
Start with n=10, then cut and paste to make n=20, etc. Do you see a trend?
BTW, you will need a column for n, and a column for the numerator of the nth term, and a column for the denominator of the nth term, and a column for the quotient of the nth term, and then a sum over that last column down at the bottom.
Yea they don't look to be zero, the first one looks like 1/3 and the second one looks like... well I don't know with n = 200 it was like .69 and n = 300 it was over 1.
Can you please give me a hint on how to actually solve these guys?
You must have taken k=2 for the first one, right? They are both Riemann sums which become exact in the limit as n -> infinity. The first one is the integral from 0 to 1 of x^k. The second one is the integral from 1 to 2 of 1/x. The first one depends on k, but if k=2 it's 1/3. That's how I knew you used k=2. The second is ln(2)=0.693... Good job using Excel (yuck!). Very brave. Review Riemann sums and see how this works, ok?
Dick thank you very much for your response. I owe you one, how about next time you need Excel help I'm your guy!
Actually the once or twice in my life I've actually used a spreadsheet, I used Openoffice Calc. But I'm sure you can you can handle that as well. I'll keep you in mind.
  • · Replies 23 ·
  • · Replies 22 ·
