Block slides from rest from the top of a fixed frictionless sphere
A small block slides from rest from the top of a fixed frictionless sphere of radius R. The vertical distance traveled by the block when it loses contact with the sphere is calculated to be x = R/3. The speed of the block at this point is determined to be v = √(2gR/3). The analysis utilizes conservation of mechanical energy and centripetal force equations to derive these results, confirming the calculations are correct.
  • Understanding of basic physics concepts such as gravitational potential energy and kinetic energy.
  • Familiarity with centripetal force and its role in circular motion.
  • Knowledge of trigonometric functions, specifically cosine, in relation to angular displacement.
  • Ability to manipulate equations involving energy conservation and motion dynamics.
  • Study the principles of conservation of mechanical energy in physics.
  • Learn about centripetal force and its applications in circular motion problems.
  • Explore trigonometric identities and their use in physics problems involving angles.
  • Practice solving problems related to motion on curved surfaces, particularly frictionless scenarios.
Students of physics, educators teaching mechanics, and anyone interested in understanding dynamics of motion on curved surfaces.
leyyee
can anyone help me to solve this question? please and thank you :D
radius R.
Determine the vertical distance traveled by the block, x , where it loses
contact with the surface of the sphere and its speed at this point.
let m be the mass of the block.
let y be the angular displacement of the block between its starting point and the point in which it loses contact with the sphere.
we can see that cos(y) = (R-x)/R, x = R[1 - cos(y)]
since there is conservation of mechanical energy, loss of gravitational potential energy will result in a gain in kinetic energy of the block, mgx = (1/2)mv2
hence, v2 = 2gx = 2gR[1 - cos(y)]
next, as the block moves down the sphere, a portion of its weight must act radially into the sphere so as to provide the required centripetal force for the motion of the block.
hence, required centripetal force = mg*cos(y) = mv2/R
substituting the value of v2 found previously into the equation, mg*cos(y) = 2mgR[1 - cos(y)]/ R
hence, rearranging the terms, we get cos(y) = 2/3
since x = R[1 - cos(y)], x = R(1 - 2/3) = R/3
since v2 = 2gx = 2gR[1 - cos(y)], v2 = 2gR/3, v = (2gr/3)1/2
is it correct?
  • a.pdf
    a.pdf
YEAh. THANK YOU!
  • · Replies 35 ·
  • · Replies 44 ·
10K
