What is the initial velocity of a rock thrown off a 20-m high cliff?
  • Thread starter Thread starter hansel13
The initial velocity of a rock thrown horizontally from a 20-meter high cliff, which strikes the ground at a 45-degree angle, is determined to be 20 m/s. The solution involves using the equations of motion, specifically the vertical motion equation v² = 0 - 2gy, where g is the acceleration due to gravity (9.8 m/s²). By calculating the final vertical velocity and recognizing the relationship between the horizontal and vertical components of velocity, the initial horizontal velocity can be derived. The final answer confirms that the rock was thrown with a speed of 20 m/s.
  • Understanding of projectile motion principles
  • Familiarity with kinematic equations
  • Knowledge of vector components in physics
  • Basic grasp of trigonometric relationships in right triangles
  • Study the derivation of projectile motion equations
  • Learn about the effects of air resistance on projectile trajectories
  • Explore the concept of vector decomposition in physics
  • Investigate real-world applications of projectile motion in sports and engineering
Students studying physics, educators teaching kinematics, and anyone interested in understanding the principles of projectile motion and its applications.
hansel13
A rock is thrown horizontally from the top of a 20-m high cliff and strikes the ground at an angle of 45 degrees. With what speed was it thrown?
R = V2/g*sin(2theta)
v2 = (v0*sin(theta))2 - 2gy
I have 2 unknowns no matter what equation I try to use. I've tried to get it down to one unknown, but I keep getting the wrong answer..
Don't think in equations, think in terms of the picture you see. You grabbed the range equation, but don't just try to plug things into it.
The rock strikes the ground at 45 degrees. That means it's final velocity has x and y components that are related to each other how? You know x velocity is constant. You can find final y velocity using that initial y velocity is zero. If you know the relation between x and y velocity, you can then find x velocity.
Ahhh, I think I understand now.
v2 = 0 - 2gy
v = (2*9.8*20)1/2
= 19.7
The correct answer is 20m/s. Thanks :smile:
  • · Replies 22 ·
