Calculating properties of steel
  • Thread starter Thread starter vtmike
    Properties Steel
The discussion focuses on calculating the Elastic Modulus and Poisson's Ratio for steel using its tensile properties. Mike initially calculated the Elastic Modulus as 843750 psi and Poisson's Ratio as 0.32, using tensile strength data. Jennifer pointed out that these calculations are incorrect because they rely on tensile strength, which is a plastic property, rather than data from the elastic region. She emphasized the importance of using the slope of the stress-strain curve in the elastic region to accurately determine these properties.
  • Understanding of tensile properties of materials, specifically steel.
  • Knowledge of stress-strain relationships in materials science.
  • Familiarity with elastic and plastic deformation concepts.
  • Ability to interpret stress-strain curves.
  • Learn how to derive Elastic Modulus from a stress-strain curve.
  • Research the differences between elastic and plastic properties in materials.
  • Study the typical ranges for Young's Modulus and Poisson's Ratio in various steel grades.
  • Explore methods for experimentally determining material properties using tensile testing.
Materials scientists, mechanical engineers, and anyone involved in the analysis or testing of steel properties will benefit from this discussion.
vtmike
Hi,
I know the following properties for steel,
Tensile Strength = 135000 psi
Yield Strength = 130000 psi
Elongation in 2 inches = 16% minimum
Reduction in Area = 50% minimum
Hardness (Rockwell C) = 29 - 34Rc
So from above properties I need to calculate the Elastic modulus & Poisson's ratio. This is how I went about it,
1. Calculate strain = change in length/original length = 2.32-2/2 = .16
2. Elastic modulus, E = stress/strain = 135000/.16 = 843750 psi
3. Poissons ratio = lateral strain/axial strain = .16/.5 = .32
Is the above procedure correct? Any help would be appreciated.
Thanks,
Mike
Hi Mike,
A few things-Poisson's ratio and the Elastic Modulus are elastic properties, so you need to calculate them with data from the elastic region. You used the tensile strength to calculate E-the tensile strength is reached in the plastic region for materials with any ductility. Plus, that stress is not the stress that caused the .16 strain (at least nothing in the problem statement states that). The tensile strength is a material property. Does the problem tell you what tensile force or nominal stress that the specimen is being subjected to (F or sigma_o, etc.)? Or give you a stress-strain curve?
If you have a strain-strain curve, you can just use the slope of the linear-elastic region to find E.
Jennifer
Keep in mind that ANY steel is going to have a Young's modulus between 26-30 ksi. Your value for Poisson's ratio is right about where it should be. It usually ranges between .28-.32 but I have seen as high as .36 for some steels.
10K
  • · Replies 0 ·
  • · Replies 18 ·
  • · Replies 35 ·
