Quantizing the Electric & Gravitational Fields: A Deeper Look
The discussion revolves around the quantization of gravitational and electric fields, exploring the interactions between gravitons and virtual photons, and the implications for a unified theory of forces. Participants consider whether these fields can be quantized independently and the role of field operators in defining probabilities for particle creation.
  • Some participants propose that if gravitons and virtual photons both have energy, they may influence each other's motion through space-time.
  • There is a question about whether the gravitational field can be quantized independently of the electric field, with some suggesting that the electric field's quantization may have been a result of adjusting equations in quantum electrodynamics (QED).
  • One participant introduces the idea that other virtual particles, such as weakons and gluons, also contribute to the vacuum energy and gravity, suggesting a more comprehensive unification of forces.
  • Another viewpoint suggests that it may not be possible to quantize gravity independently of other fields, and that QED's success might be an exception rather than a rule.
  • Participants discuss the potential interactions between gravitons and photons, noting that these interactions might be significant near their points of origin but negligible at large distances.
  • There is speculation about modeling the effect of gravitons on photons, particularly regarding the expected deflection of photons in the presence of gravitons.
  • One participant raises the idea that gravitational redshift might not be considered in QED due to the uniformity of electric charges, which could lead to a cancellation effect.
  • Concerns are expressed that gravity cannot be quantized properly if the electric field has not been quantized adequately.
Participants express multiple competing views regarding the quantization of gravitational and electric fields, and the discussion remains unresolved with no consensus reached on the independence of these fields or the nature of their interactions.
Participants highlight various assumptions about the nature of virtual particles and their interactions, as well as the limitations of current theories in fully addressing the complexities of quantizing gravity alongside other fields.
kurious
If a graviton has energy presumably it curves space-time.A virtual
photon has energy and presumably it curves space-time.So can a
graviton affect the motion of a virtual photon through space-time and
vice-versa? If so, can the gravitational field be quantized
independently of the electric field?
Does there have to be a field operator that gives two probabilities
for each point in space: one probability for creating particles for
the gravitational field and another probability for creating particles
for the electric field ?
The electric field has been quantized independently of the
gravitational field but was this just the inevitability of "adjusting"
equations in QED?
equations in QED?
For me these are interesting questions you are asking. Can we look at light cones here?
equations in QED?
Why stop at electromagnetism? The quantum vacuum also contains virtual weakons which have energy and gravitate as well as the virtual gluons and quarks of QCD. So all the forces and matter particles can be virtual as well as observable, and would contribute to the energy of the vacuum, and thus to gravity. So yes, a complete theory that unifies the forces and quantizes gravity is going to have them all interacting with each other.
Essentially what I am saying is this: maybe it isn't possible to quantize gravity independently of the other fields and QED was lucky to get away with it.
And perhaps qcd isn't a perfect theory for the same reason.
The standard model assumes that the forces are not unified now in the low
energy conditions of the universe, at present, but this doesn't necessarily mean they are independent of one another?
Gravitons and photons will interact only slightly over large distances because
they don't curve spacetime significantly and can be widely separated in space, but at their point of origin near a particle they could interact significantly. Photons would affect photons ,gravitons would affect gravitons and there would be graviton-photon interactions too.
If gravitons have mass would it be reasonable to model their
effect on photons usng the idea that the expected deflection of a photon is twice the Newtonian prediction for one photon and one graviton.Is the relativistic deflection of a photon always twice the Newtonian deflection regardless of distance and energy density?
QED probably gets away with not considering gravitational redshift of photons because electric charges have the same magnitude and so a photon redshifted as it is emitted by one charge will be blueshifted back to its
original frequency as it gets absorbed by another charge.
Also the lamb shift is a phenomenon at 10^-10 metres and photons in QED that have interacted in complex ways at smaller distances would have time and space to rearrange themselves and behave as flat space QED says they should.I reckon gravity can't be quantised because the electric field hasn't been quantised properly yet!
SOL:
What did you have in mind with light cones?
  • · Replies 30 ·
  • · Replies 24 ·
