Pulley problem with definite mass rope
The discussion revolves around a physics problem involving a pulley with a circumference of 1.20m and a mass of 2.25kg, along with a heavy rope of 8.00m length and 4.80kg mass. The problem requires calculating the angular velocity of the pulley when one end of the rope leaves the pulley after being released from rest. Key equations include the conservation of energy, where the initial potential energy (PE) is calculated based on the height difference of the rope, and the kinetic energy (KE) of both the rope and the pulley is considered. The solution emphasizes the importance of defining the reference point for potential energy and correctly identifying the mass contributing to kinetic energy.
  • Understanding of rotational dynamics and angular velocity
  • Familiarity with conservation of energy principles in mechanics
  • Knowledge of potential energy and kinetic energy equations
  • Ability to analyze systems involving pulleys and ropes
  • Study the principles of rotational motion and angular momentum
  • Learn about the conservation of mechanical energy in dynamic systems
  • Explore the concept of reference points in potential energy calculations
  • Practice solving similar pulley problems using different mass configurations
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators seeking to enhance their understanding of pulley systems and energy conservation principles.
Hopelessmin
Hi, I've been working on this problem for more than 4 hours now. and I haven't got a clue on how to finish the problem. ANY help would be tremendously appreciated!
Thanks!
a pulley has a circumference of 1.20m and mass of 2.25kg. pulley is a solid uniform disk. a heavy rope, 8.00m in length with a mass of 4.80kg hangs over the pulley with one end of the rope 0.600m lower than the other end of the rope. the pulley is initially at rest. when the pulley is released, the pulley turns as the lower end of the rope accelerates downward. assume no slippage. what is the angualr velocity of the pulley at the moment the end of the rope leaves pulley?
v=wr
I=mR^2
L1+L2+1/2(circumference)=8.00m
PEi=KE(translation)+KE(Rotation)
ok so we know L1+L2+1/2(circumference)=8.00m; therefore, L1=3.4m, and L2=4.0m.
the initial potential energy is mg(4.00m) because the rope will leave pulley after it moves 4.00m more. The problem is that I don't know which mass to use. Do i use the mass of the whole rope? the mass changes as the rope falls over the pulley, as well as its acceleration.
ignoring the ambiguity of mass, our KE(trans)+KE(rotat)=1/2(mass1)(v^2)+1/2(mass of pulley)R^2)(w^2)=1/2(m)(rw)^2+1/2(mR^2)(w^2). In this equation, I don't know what is mass1. is it the mass of entire rope?
I am not even sure if my PE is right. So any help would be truly appreciated! Thanks in advance, Physics Forum members :)
Welcome to PF!
Hi Hopelessmin! Welcome to PF! :smile:
(have an omega: ω and a squared: ² :wink:)
All PE is relative!
So starting with "the initial potential energy is …" is wrong … just state what your "base" of PE is (in this case, choose "base" PE as being when the two ends are of equal length), and just use the difference in PE from that. :smile:
(and once you do that, it is obvious how much of the rope you use! :wink:)
How much of the rope is moving? That's what has KE. :wink:
Then solve the equation KE + PE = constant. :smile:
  • · Replies 22 ·
  • · Replies 40 ·
  • · Replies 30 ·
