How High Must the First Hill Be for a Skier to Lose Contact at the Crest?
  • Thread starter Thread starter Klassic
    Em
The discussion revolves around a physics problem involving a skier descending from a hill and losing contact at the crest of a second circular hill with a radius of 36 m. The problem requires understanding of centripetal acceleration and energy conservation principles, specifically in the context of gravitational forces and motion on slopes.
  • Participants discuss the relationship between gravitational force and centripetal acceleration, noting that the skier loses contact when the normal force is zero. There are attempts to equate kinetic and potential energy to find the necessary height of the first hill. Additionally, the second problem is approached by separating the motion into two parts: the descent down the slope and the free fall, with considerations for friction affecting energy conservation.
Some participants have provided insights into the equations needed to analyze the problems, while others express uncertainty about their calculations and seek confirmation of their results. There is an ongoing exploration of the concepts involved, with no explicit consensus reached on the final answers.
Participants mention the requirement to attempt problems before seeking help, indicating a focus on understanding rather than simply obtaining answers. There is also mention of potential round-off errors in calculations, highlighting the importance of precision in problem-solving.
Klassic
I understand that it is required that a user have attempted the problems before posting as this is not a place where people will do your homework for you. I'm a relatively good physics student, and was just handed a 30 problem packet to complete. I've spent the majority of my weekend figuring these problems out, and I'm left with 2 problems that I'm having a great deal of trouble with. The problems are:
A skier starts from rest at the top of a hill. The skier coasts down the hill and up a second hill. The crest of the second hill is circular with a radius of r=36 m. Neglect friction and air resistance. What is the height of the first hill such that the skier just loses contact with the snow at the crest of the second hill?
I've figured out that to figure out this problem, you must have a strong bearing on the concepts of centripetal acceleration/force. I don't entirely grasp those concepts. I'm having a hard time even getting a grasp on this problem.
Second:
An extreme skier, starting from rest, coasts down a mountain that makes an angle of 25.0 degrees with the horizontal. THe coefficient of kinetic friction between her skis and the snow is 0.200. She coasts for a distance of 10.4 m before coming to the edge of a cliff. Without slowing down, she skis off and lands downhill at a point whose vertical distance is 3.50 m below the edge. How fast is she traveling just before she lands?
Again, I'm aware this is not really a "homework help" place. But please realize that I have attempted both problems - and failed miserably. The other problems have obviously tired my brain. ANY help would be very much appreciated. Please~. :)
In the first case, gravity is evidently the force providing centripetal acceleration.
The skier will lose contact with the surface if the NORMAL FORCE IS ZERO.
This means that the force of gravity must provide exactly the centripetal acceleration
(otherwise, there would have been a non-zero normal force)
Hence, the requirement for loss of contact is:
[tex]mg=m\frac{V^{2}}{r}[/tex]
(I assume you know what numbers to plug in here.. :smile:)
What you are looking for is to find the velocity he requires such that at the top of the second hill his centrifugal force (something like [tex]m v^2 / r[/tex] where r is the radius of the hill) is no longer balanced by gravity, [tex]mg[/tex]. Since there is no friction you should be able to calculate his velocity at any time by equating KE to PE, ie
[tex] 1/2 m v^2 = mg \Delta h[/tex]
where [tex]\Delta h[/tex] is the difference between his current and initial height.
Hope that helps.
Matt
In the second problem, it is important to separate the motion in 2 distinct parts.
1. Part: Down the slope.
2. Part: Free fall.
The 2.part is rather simple, so I'll give a few hints in order for you to solve the 1.part:
Clearly, due to friction, mechanical energy is not conserved; you must take into account the work done by friction.
To help you on a bit, I'll give the magnitude of the frictional force:
[tex]F=\mu{N},N=mg\cos(25)[/tex]
It's Klassic. A little homework trouble. THANKS SO MUCH.
Did you guys get for number one: 18.08.
As for the second question, I'm a little confused. If you could elaborate, that'd be great. :)
Thanks again!
Alright, thanks guys. I definitely figured out #2 - thanks, aril, I figured out how to apply that. Many thanks.
As for #1, I think I got it: 18.08, but I would really like a confirmation if any of you are willing because I'm not entirely content. I used both equations you two gave me.
Again, much appreciated.
Thanks~
Unfortunately, you have round-off errors in your first answer; it should be EXACTLY 18!
Reason:
We have:
[tex]\frac{1}{2}mV^{2}=mg\bigtriangleup{h}[/tex]
Eliminating factor mV^{2} from the first equation yields:
[tex]\frac{mgr}{2}=mg\bigtriangleup{h}\rightarrow\bigtriangleup{h}=\frac{r}{2}[/tex]
  • · Replies 23 ·
9K
