Prove two integrals are the same using U substitution
The discussion revolves around proving the equality of two integrals involving powers of \(x\) and \(1-x\) using U substitution. The integrals are defined over the interval from 0 to 1, with parameters \(a\) and \(b\) being positive numbers.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the application of U substitution, particularly setting \(U = 1-x\) and the implications for the differential \(dx\) and the limits of integration. There is an exploration of the commutative property of multiplication in the context of the integrals.
Some participants have provided insights into the implications of U substitution, noting the need for careful handling of the differential and integration limits. There is recognition of the relationship between the two integrals, but no consensus on the final steps to complete the proof.
Participants are constrained by the requirement to use only U substitution without employing multiplication rules or other techniques, which adds complexity to the problem-solving process.
v0id19
If a and b are positive numbers, show that [tex]\int_0^1 x^a*(1-x)^b\,dx = \int_0^1 x^b*(1-x)^a\,dx[/tex] using only U substitution.
Just U substitution and the given equation--I can't use multiplication rules or anything like that; otherwise it would be easy.
I tried to set U=(1-x) and I end up with [tex]\int_0^1 (1-U)^a*(U)^B\,dx[/tex] for the right side, but that doesn't seem to get me anywhere. I know I somehow need to switch the places of the x and (1-x) but I can't seem to get around going in a circle and ending up with what I started with.
Multiplication of real numbers is commutative, so
[tex] (1-U)^a*U^b=U^b*(1-U)^a[/tex]
Or does * denote something different from multiplication of real numbers?
If you let U = 1-x you also have dx=-dU. Morover your integration bounds change. You need to be more careful in applying the u substitution rule.
yeah I just realized that, thanks
[tex]\int_1^0 (1-U)^a*(U)^b\,(-du) = \int_0^1 (1-U)^a*(U)^b\,(du)[/tex] but I still get stuck there. Why would switching the order of (U-1)a and Ub help?
Haven't you just shown
[tex] \int_0^1{x^a(1-x)^bdx}=\int_0^1{u^b(1-u)^adu}[/tex]
How does this relate to the original question you are asked to prove? Remeber, that it doesn't make a difference how you call the integration variable. x, u, whatever, it is only a label.
Oh. Wow. That makes sense!
Thanks a bunch! :biggrin:
  • · Replies 27 ·
  • · Replies 105 ·
13K
