Geometric Sequence; Arithmetic Sequence w/o 2,3,7
The discussion addresses several mathematical problems involving geometric and arithmetic sequences. Problem 8 requires finding values for x and y in the geometric sequence defined by 2y, 2xy, 2, xy/2, resulting in x = 2 and y = 4. Problem 9 presents an arithmetic sequence with terms not divisible by 2, 3, or 7, exemplified by 5, 11, 17, 23, and 29. Problem 10 identifies the first five common terms between two arithmetic sequences, A and B, yielding the terms 9, 16, 23, 30, and 37. Lastly, Problem 11b discusses conditions for having two distinct common ratios in a geometric sequence based on the relationship between the given terms.
  • Understanding of geometric sequences and their properties
  • Knowledge of arithmetic sequences and their characteristics
  • Familiarity with mathematical induction techniques
  • Ability to solve simultaneous equations
  • Study the properties of geometric sequences in detail
  • Explore arithmetic sequences and their applications in number theory
  • Learn mathematical induction and its proofs
  • Investigate the relationship between common ratios and terms in geometric sequences
Mathematics students, educators, and anyone interested in advanced sequence analysis and problem-solving techniques in algebra.
mustang
Problem 8.
Find x & y if the sequence 2y, 2xy, 2, xy/2,...is geometric.
Problem 9.
Find an arithmeitc sequence none of whose terms are divisible by 2, 3, or 7.
Prtoblem 10.
Consider two arithmetic sequences:
A:3, 14, 25.. B: 2, 9 , 16, ...
Write the first five terms of sequence A that are also terms of sequence B.
Problem 11b. Given two terms of a geometric sequence, under what conditions will there be two different common ratios that could be used to find two sequences that have the given terms?
Problem 16. Show that 1 + 2 + 4 +...+2^(n-1)=2^(n)-1
Yep, looks like Algebra 2 problems.
Problem 8. To find x and y, we can use the formula for a geometric sequence: a_n = a_1 * r^(n-1). In this case, a_1 = 2y and a_2 = 2xy, so we have 2xy = (2y) * r. Similarly, a_3 = 2 and a_4 = xy/2, giving us xy/2 = 2 * r^2. Solving these equations simultaneously, we get x = 2 and y = 4.
Problem 9. An example of an arithmetic sequence that does not have terms divisible by 2, 3, or 7 is: 5, 11, 17, 23, 29, ...
Problem 10. The first five terms of sequence A that are also terms of sequence B are: 9, 16, 23, 30, 37.
Problem 11b. There will be two different common ratios if the two given terms are not consecutive terms in the geometric sequence. In other words, if the common difference between the two given terms is not a multiple of the common ratio.
Problem 16. We can use mathematical induction to prove this statement.
Base case: When n = 1, the left side is equal to 1, and the right side is equal to 2^(1) - 1 = 1. So the statement holds true for n = 1.
Inductive step: Assume the statement holds true for n = k, i.e. 1 + 2 + 4 + ... + 2^(k-1) = 2^(k) - 1.
For n = k+1, we have 1 + 2 + 4 + ... + 2^(k-1) + 2^(k) = 2^(k+1) - 1.
Adding 2^(k) on both sides, we get 1 + 2 + 4 + ... + 2^(k-1) + 2^(k) + 2^(k) = 2^(k+1) - 1 + 2^(k).
Simplifying, we get 1 + 2 + 4 + ... + 2^(k) + 2^(k) = 2^(k+1) -
