How do you prove that some point is the *only* accumulation point in a set?
  • Thread starter Thread starter killian
    Point Set
The discussion revolves around proving that a specific point, 0, is the only accumulation point of the set A = {1/n : n ∈ ℤ⁺}. The original poster is working with the definition of an accumulation point and is seeking to establish the uniqueness of 0 as an accumulation point for the given set.
  • The original poster has demonstrated that 0 is an accumulation point but is uncertain about how to rigorously prove that no other points can be accumulation points. Some participants suggest considering specific values and cases to explore the conditions under which other points could be accumulation points.
Participants are actively engaging with the problem, offering suggestions for rigorous approaches and exploring the implications of the original poster's intuitive understanding. There is a focus on clarifying the conditions that would allow for other accumulation points and the uniqueness of 0.
The discussion includes considerations of epsilon neighborhoods and the behavior of the sequence defined by the set A. There is an emphasis on the need for a rigorous formulation of the original poster's intuitive reasoning.
killian
I'm using the following definition of an accumulation point:
A point [itex]a \in \textbb{R}[/itex] is an accumulation point of a set [itex]A\subset \textbb{R}[/itex] if every [itex]\epsilon-[/itex]neighborhood of [itex]a[/itex] contains at least one element of [itex]A[/itex] distinct from [itex]a[/itex].
Now, given the set [itex]A=\{\frac{1}{n}:n\in \textbb{Z}^+\}[/itex], I'm trying to prove that the only accumulation point of [itex]A[/itex] is 0.
2. The attempt at a solution
I was able to prove that 0 is an accumulation point, but my question is about proving there can't be any others.
Intuitively, it makes sense to me because any element between 0 and 1 is either an element of [itex]A[/itex] or between two elements of [itex]A[/itex]. In either case, you can take [itex]\epsilon[/itex] small enough to not include any elements of [itex]A[/itex].
The problem I have is that I'm not sure how to formulate this in a way that would be considered rigorous.
Having the right picture of the problem is the first step. And you've got that. Given n, what's an epsilon the would be less than both (1/n-1/(n+1)) and (1/(n-1)-1/n)? If you can find one, that would fulfill your intuitive sense in a rigorous way. Yes?
Let [itex]\alpha[/itex] be any number other than 0. Show that [itex]\alpha[/itex] is not an accumulation point.
You probably should do two cases: (1) [itex]alpha> 0[/itex] and (2) [itex]\alpha[/itex]< 0. Sjhow that there are only finite number of n such that [itex]|1/n|> \alpha[/itex].
Well, how about letting z be an accumulation point, and then prove that it must equal zero?
That is, prove the uniqueness of zero as an accumulation point!
  • · Replies 25 ·
