How do I reverse the order of integration for this double integral?
The discussion revolves around evaluating a double integral by reversing the order of integration, specifically the integral \(\int^1_0\int^1_{y^2} y\sin(x^2)dxdy\). The subject area includes calculus and integration techniques.
  • Mixed
  • Participants discuss the limits of integration and the region of integration, with some attempting to graph the area to visualize the problem. Questions arise regarding the correctness of the limits and the interpretation of the region bounded by the curves.
There is ongoing exploration of the limits of integration and the graphical representation of the region. Some participants have offered clarifications regarding the limits, while others express confusion about the relationship between the curves and the area of integration.
Participants note potential misunderstandings regarding the graphical representation of the region and the implications of the limits of integration, particularly concerning the area above or outside the parabola.
squeeky
Evaluate an iterated integral by reversing the order of integration
[tex]\int^1_0\int^1_{y^2} ysin(x^2)dxdy[/tex]
I've got that the limits for x is between y^2 and 1, while the limits for y is between 0 and 1. Then I graphed it:
Looking at it from bottom to top, I see that it enters the region at y^2 and leaves at 1. While from left to right, the lowest limit x can be is -1, while the highest is 1. So now I have an integral of [tex]\int^1_{-1}\int^1_{\sqrt{x}}ysin(x^2)dydx[/tex].
Integrating the first part of the equation for y, I get:
[tex]\int^1_{-1} \frac{sin(x^2)}{2}-\frac{xsin(x^2)}{2}dx[/tex]
And it's at this point that I get stuck. I know that I can break up the problem and integrate each part separately, which makes solving the second part easy, since I can just use substitution, but I'm just not sure how to integrate the [tex]\frac{sin(x^2)}{2}[/tex] part. I'm wondering whether this means that I got the limits wrong, or I'm just forgetting trig integrals.
What curves is the region in your question bounded by? I don't believe you included that and it makes it difficult to check what your limits of integration should be.
As I'm not sure what region you want the limits of integration for, It seems to me from your graph that you chose the correct ones. Have you tried Taylor expanding the first time to the desired degree of accuracy?
Your picture is wrong. The area over which you are integrating is NOT the are you have shown in yellow. With x going from y2 to 1, you want to integrate over the region outside the parabola to the line x= 1 on the right.
Thanks, that solves the problem! Although, I can understand where I went wrong with taking the limits for x, but I still don't quite get why the region is the area outside the parabola, instead of inside.
The second integral has lower limit x= y2 and upper limit x= 1. That order is verified by the fact that for y from 0 to 1 y2<= 1 so that is from x= y2 UP to x= 1.
I don't know, I still don't get it. I mean yeah I understand the x-limits, it's just the y-limits I'm having problems with. Referring to the original integral, we have the limits of x being greater than y^2 and less than 1, so wouldn't that make the region above the parabola, since it has to be greater than the parabola?
NO! "x> y2" (x positive) means "[itex]\sqrt{x}> y[/itex]" or [itex]y< \sqrt{x}[/itex].
x greater than a function of y means y is less than that inverse function of x.
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 105 ·
13K
