Volume Using Polar Coordinates
by squeeky
Tags: coordinates, polar, volume
squeeky
squeeky is offline
#1
Nov15-08, 07:36 PM
P: 9
Use polar coordinates to find the volume bounded by the paraboloids z=3x2+3y2 and z=4-x2-y2
2. Relevant equations
3. The attempt at a solution
Somehow, through random guessing, I managed to get the right answer, it's just that I don't understand how I got it. Also, because the z is involved, I actually used cylindrical coordinates, but would that still be considered the same thing as polar coordinates? So anyway, I changed the two paraboloid equations to z=3r2 and z=4-r2. Then setting these two equations equal to each other (since they are both equal to z), I solved for r and got the limits of -1,1. For the limits of theta, I just happened to take it from 0 to 2pi. Lastly for the z limits, I just tried from 4-r2 to 3r2, so that gave me the equation:
[tex]\int^{2\pi}_0\int^1_{-1}\int^{3r^2}_{4-r^2}dzrdrd\theta[/tex]
However, solving this equation didn't give me the right answer, so I changed the limits of r to 0 to 1, and switched the z-limits around, so now it is:
[tex]\int^{2\pi}_0\int^1_0\int^{4-r^2}_{3r^2}dzrdrd\theta[/tex]
And solving for this, gave me the right answer of 2pi. The problem is that I don't understand the real logic behind what I did.
So in summary, what I didn't understand was how to establish the limits for theta, r, and z.
Phys.Org News Partner Science news on Phys.org
Simplicity is key to co-operative robots
Chemical vapor deposition used to grow atomic layer materials on top of each other
Earliest ancestor of land herbivores discovered
HallsofIvy
HallsofIvy is offline
#2
Nov16-08, 04:07 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 38,879
Quote Quote by squeeky View Post
Those two paraboloids intersect when z= 3x2+ 3y2= 4- x2- y2 or 4x2+ 4y2= 4 which reduces to x2+ y2= 1. That projects onto the xy-plane as the unit circle. It shouldn't be hard to see that the volume you want is above that circle. To cover that circle, [itex]\theta[/itex] goes from 0 to [itex]2\pi[/itex] and r goes from 0 to 1. Those are your limits of integration.
For each (x, y), the upper boundary is z= 4- x2- y2 and the lower boundary is z= 3x2+ 3y2. The volume of a "thin" rectangular solid used to construct the Riemann sums for this volume would be [(4- x2- y2)- (3x2+ 3y2)]dxdy= (4- 4x2- 4y2)dxdy= 4(1- x2- y2)dxdy and that, in polar coordinates, is 4(1- r2)rdrd[itex]\theta[/itex].
Yes, "cylindrical coordinates" is just polar coordinates in the xy-plane.
No, you didn't. Or you shouldn't. r cannot be negative. r must be between 0 and 1.
Did you think at all about the geometry of the situation? This has circular symmetry. To cover the entire volume you have to cover the entire circle: 0 to [itex]2\pi[/itex].
Surely you recognized that z= 4- r2 is ABOVE z= 3r2 for r<= 1?
Register to reply
Related Discussions
From polar coordinates to heliocentric ecliptic coordinates Astrophysics 0
Polar Coordinates Introductory Physics Homework 2
Finding the volume under a plane and region (polar coordinates) Calculus 2
polar coordinates Calculus & Beyond Homework 2
Cartesian coordinates and in polar coordinates? Introductory Physics Homework 1
