Thread Closed
Thermodynamics: Q=mc(deltaT)
Share Thread Thread Tools
Nov16-08, 12:51 PM   #1
In a physics lab experiment a student immersed 191 one-cent coins (each having a mass of 3.00 g) in boiling water, at a temperature of 100 degrees C. After they reached thermal equilibrium, she fished them out and dropped them into an amount of water of mass 0.275 kg at a temperature of 17.0 degrees C in an insulated container of negligible mass.
What was the final temperature of the coins? (One-cent coins are made of a metal alloy - mostly zinc - with a specific heat capacity of 390 J/(kg * K).)
Use 4190 J/(kg* K) for the heat capacity of the water.
2. Relevant equations
Q=mc(deltaT)
Q1 + Q2=0
3. The attempt at a solution
I'm not sure where you can get a workable system of equations from this problem. I tried finding the Q of the coins, which I found to be Q=(191*.003kg)(390)(T-100) where T=the final temperature of the coins. And the Q of Water: Q=(.275)(4190)(T-17).
You also know that the Q of water and the Q of the coins must be equal to 0 because they are in an insulated container.
Because the water is heated and the coins are cooled, you know that the Q for water is positive and that Qwater=Qcoins, However, they have different final temperatures and I'm not sure how to find one in terms of the other so I can solve the equation I've come up with. Please help!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Hong Kong launches first electric taxis
>> Morocco to harness the wind in energy hunt
>> Galaxy's Ring of Fire
Nov16-08, 01:08 PM   #2
Recognitions:
Homework Helper Homework Help
I don't know if you did it on purpose or by accident, but you used the same letter T in both equations. Is it really the same? If not, use a different letter. But if you can argue they are, you can set Qwater = Qcoins which gives you: 191*0.003*390*(T - 100) = 0.275*4190*(T - 100) and solve for T (one equation, one unknown).
Nov16-08, 01:35 PM   #3
You can't assume the final temperatures are the same, sorry. So Qcoins=Qwater but
(191*.003)(390)(R-100)=.275(4190)(T-17)
Nov17-08, 09:08 AM   #4
I guess you can assume the final temperatures are equal. I think it was a problem with my signs in that I overcompensated for the fact that the coins lose heat, so they have a negative value for Q. The final temperature will obviously be less than 100 so I suppose that accounts for the sign change.
Thread Closed
Thread Tools
Similar Threads for: Thermodynamics: Q=mc(deltaT)
Thread Forum Replies
Prof teaches Statistical thermodynamics in a Classical Thermodynamics class Academic Guidance 10
Thermodynamics Introductory Physics Homework 0
thermodynamics General Engineering 1
Thermodynamics General Physics 1
Second Law of Thermodynamics Introductory Physics Homework 1
