Thread Closed
Simple question about definition of tangent bundle
Share Thread Thread Tools
Nov16-08, 02:20 PM   #1
So I'm trying to learn about fibre bundles and I am looking at the example of a tangent bundle.
Given a differentiable manifold M. Denote the tangent space at [tex]p \in M[/tex] by [tex]T_p M[/tex]. Is the definition of the tangent bundle
[tex]TM = \lbrace (p, T_p M)|p \in M \rbrace[/tex]
or is it
[tex]TM = \lbrace (p, V)|p \in M , V \in T_p M\rbrace[/tex]?
Maybe I'm splitting hairs but there should be standard definition of one or the other, right?
I can discuss further why I think it matters but first let's just see if anyone is certain about the answer.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Nov16-08, 03:03 PM   #2
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by pellman View Post
I feel I should point out that the definition of a bundle over M is a continuous map of topological spaces with codomain M. In other words, you need to specify:
1. A topological space E, which consists of
1a. A set of points |E|
1b. A topology on |E|
2. A continuous function E --> M (often called the 'projection map', or the 'structure map')
Assuming you use the obvious projection map, this is a very boring bundle: the projection is bijective! And if you include the local triviality condition, the projection is actually a homeomorphism!
Assuming you use the obvious projection map and choose the appropriate topology, this is indeed a tangent bundle. (There are many tangent bundles; they're just all isomorphic)
Nov16-08, 03:24 PM   #3
Hurkyl, you da man. Thanks for the quick response.
So bijective is bad? That's part of what I don't get. I'm following Nakahara. You can see the page I am on here http://books.google.com/books?id=cH-...um=1&ct=result
So when he says [tex]\pi^{-1}(p)=T_p M[/tex] he's being very loose with the inverse notation, right? [tex]\pi^{-1}[/tex] doesn't really exist, since [tex]\pi((p,V))=p[/tex] for every [tex]V \in T_p M[/tex]?
Nov16-08, 04:11 PM   #4
Recognitions:
It would be -- roughly speaking such a bundle has only one section. If it were the tangent bundle, that would mean that there is exactly one vector field.
He's using the "inverse image" function, and being (very slightly) liberal with equality, since with the definition you gave, the fiber should be [itex]\{ p \} \times T_p M[/itex].
Nov16-08, 05:07 PM   #5
Ok. That gives me enough to press on. I'm sure I will get it when I see other examples. Thanks again.
Thread Closed
Thread Tools
Similar Threads for: Simple question about definition of tangent bundle
Thread Forum Replies
Tangent bundle on the sphere Differential Geometry 8
Tangent bundle of a differentiable manifold M even if M isn't orientable Calculus & Beyond Homework 1
Tangent bundle geometry and Lagrangian dynamics General Physics 14
simple question, tangent line Calculus 18
Simple question about definition of Mutual Inductance Introductory Physics Homework 1
