Is the Collision and Friction Report Accurate?
The discussion revolves around a scenario involving two carts of equal mass colliding head-on and rebounding with a higher speed than their initial speed. Participants are evaluating the accuracy of a report regarding momentum conservation and the role of potential energy in the collision.
  • Participants explore various assessments of the report, questioning the implications of momentum conservation and the conditions under which potential energy might be involved. Some express confusion over the relationship between potential energy and kinetic energy in the context of the collision.
The discussion is active, with participants raising questions about the definitions of potential energy and momentum conservation. Some guidance has been offered regarding the nature of potential energy in collisions, but there is no explicit consensus on the interpretations being explored.
Participants are considering various scenarios, such as the presence of friction, the effects of an inclined surface, and the role of potential energy in the collision dynamics. There is uncertainty regarding the assumptions made in the original problem statement.
nach
Two carts having the same mass travel towards each other, each with a speed of 1m/s relative to the surface. The carts collide head on and are reported to rebound after the collision, each with a speed of 2m/s relative to the surface. Which of the following assesments of this report is correct?
a) Momentum was not conserved therefore the report is false
b) If potential energy was released to the carts during the collision, the report could be true
c) If the carts had different masses, the report could be true
d) If the surface was inclined the report could be true
e) If there was no friction between the carts and the surface the report could be true
I feel it'll be either b) or d) but arent they essentially talking about the same idea? If they were on an incline, the potential energy will be released
Welcome to PF!
Hi nach! Welcome to PF! :smile:
No, gravity has no effect … immediately after the collision, the carts are the same distance apart (zero! :biggrin:) and therefore at the same heights, as they were immediately before the collision. :smile:
But momentum is always conserverd in a collision.Does it mean option d)
If there was no friction...
is correct?
how to say there is no friction between cart and surface,
is correct?
ah … I think you're misunderstanding what they mean by "potential energy" in (b) …
they mean something like a spring, which is wound up (or compressed) before the collision, so that it has potential energy, and then allowed to expand again, so as to release that potential energy. :smile:
More thought on this question...
Does it mean that potential energy is released whenever there is head on collision and the two bodies travel in opposite direction?
No … the situation in the question is highly artificial …
in most collisions, either no potential energy is involved (why would there be a spring?), or potential energy is taken up, not released …
when a car crashes, it has a "crumple zone" which absorbs some of the energy … you could say that some of that absorbed energy has been converted into potential energy.
Even if potential energy was released, how can it be that the RESULTANT speed after the collision is greater than that before??because they are moving at 1m/s initially and after the collision the speed is 2m/s...
Because PE + KE = constant,
so if the PE decreases, then the KE increases.
"Releasing" PE means that there was PE before and there isn't now, so the PE has decreased …
so that supplies the extra KE needed to give the extra speed. :wink:
Since there was no PE before collision,so part of KE gets converted in PE in the collision.This same PE is released after the collision ,but how can it increase the KE ?
No, there was PE before the collision … probably in the form of a compressed spring.
OHH..i think i understand...thanks a lot!
  • · Replies 32 ·
