Reflection with a complex material
The discussion revolves around the measurement of the refractive index of plant sap using a digital refractometer, focusing on the complexities introduced by the sap's composition, which includes water, sucrose, and various other compounds. Participants explore how these factors affect the reflective properties of light at the interface between the refractometer's prism and the sap.
  • Toby describes the challenge of determining whether refractometer readings are influenced by the water-soluble content alone or also by the structural components of the sap.
  • Some participants suggest that as long as the illumination size is sufficiently large, the solution can be treated as homogeneous.
  • One participant explains that the refractometer operates on the principle of critical angle and total internal reflection, noting that the refractive index of the fluid affects the amount of light reflected towards the sensor.
  • Another participant mentions that the refractometer measures total dissolved solids, implying that the contribution of various components to the refractive index can be additive.
  • Toby raises a concern about the size of proteins and enzymes relative to the wavelength of light, questioning whether they could affect the critical angle and thus the readings.
  • Toby observes that rolling the grass sample before measurement significantly increases the refractometer reading, suggesting that the physical disruption of the sample alters the composition affecting the readings.
  • There is a request for a detailed atomic-scale description of photon interactions with the sap's components, indicating a desire for deeper understanding of the underlying physics.
  • One participant cautions against extrapolating microscopic descriptions from macroscopic measurements, noting that proteins are small compared to the wavelengths of visible light.
Participants express differing views on the extent to which the composition of the sap affects refractometer readings, with some suggesting minimal impact from larger compounds while others highlight significant effects from structural components. The discussion remains unresolved regarding the precise interactions at the atomic level.
Participants acknowledge limitations in understanding the effects of various compounds on refractive index readings, particularly regarding the assumptions of homogeneity and the influence of larger particles on measurements.
vadar
Hey
I am currently looking into refractometry, and how light reflects off a interface between to materials. I have looked through most of the other threads but nothing really explained what I am looking for.
My problem, I have a digital refractometer and I am measuring the reflective angle of plant sap through its internal glass prism. However, plant sap contains a water-surcose solution, with free compounds like protiens, minerals, cellulose etc. Because of this I am not sure if my refractometer index readings are a function of the water-soluble content (water, surcose, fructans) or the water-soluable and structural content (+ the proteins minerals etc.).
If the incident light is in a perfect material, say glass, and hits a second material which has many different types of compounds and atoms in it, what happens to the reflected light and its angle?
I notice that you should treat the material as a whole structure when photons hit it. But if this material has many different atoms, molecules and structures at this interface you can't apply this simple rule.
Thanks in advance and any ideas would be greatly appreciated.
Cheers
Toby
Science news on Phys.org
One thing I should add,
The refractometer is finding the refractive index of the sap by reflecting light off it onto a small CCD sensor. From the critical angle of the sap glass interface, a shadow is cast over the CCD and it finds the refractive index from measuring this amount of pixels lit up by the light.
As long as the transverse size of the illumination is large enough (more than a few hundred microns), you can consider the solution to be homogeneous.
Toby:
Your digital refractometer works on the critical angle basis. Light incident on the boundary layer of the prism and air will be totally internally reflected. However when the air at the boundary interface is replaced with a fluid (with a refractive index lower than the refractive index of the prism), some of the light will be reflected off the boundary interface towards the linear array of photodiodes and some of the light will be lost. As you stated, the portion of light that is reflected forms a shadowline on a linear array of photodiodes. The relative position of the shadowline is representative of the refractive index of the fluid.
You can use Snells’s Law to calculate the interaction at the boundary interface. Most handheld digital refractometers use a standard glass prism made of BK-7 glass with a refractive index of ~1.51673 @20°C. MISCO Refractometer uses only sapphire prisms which have a much higher refractive index.
Concerning your question on fluid composition, on the most basic level, a refractometer really just measures total dissolved solids. As Andy Resnick said, you should consider the solution to be homogeneous, meaning there is one uniform refractive index throughout the solution. For your purposes consider the dissolved solids as being additive to the total refractive index of the solution.
In the case of plant sap, it is likely that the majority of the dissolved solids will be sucrose with a much smaller contribution (almost negligible) from the other components. The other components would have to be in an equivalent concentration of greater than 0.1% sucrose by weight before they would even change the refractive index by 0.0001 nD20.
Good Luck!
MISCO Refractometer
Hey Andy and Mrainer, thanks for the help i appreciate it !
Andy, I would assume the enzymes and protiens would be much larger than the wavelength, wouldn't this mean the photons that hit these compounds would have a different critcal angle, and hence I would obtain different readings ?
Mrainer...
I realize this extra compound content should have a minimal effect, however, simply rolling a grass sample before it is crushed increases the refractometer reading (2% brix (not rolled) upto 10% brix (rolled for >1min)) I assume by doing this I am breaking up the cell wall of the sample and this is introduced to the sap, which in turn increases the reading. Even rolling the sample for 5 seconds will increase a reading by ~1% brix. So I'm guessing these cell wall compounds are large, and affecting the brix reading.
I guess what I am asking is even when I do not roll the sample, the sap will contain solids which noticably affect the refractometer reading?
Could you give me a more detailed description of exactly what is happening on an atomic scale, with an interface which cotains surcose water and many larger compounds and solids, in terms of photons and their interaction with this solution. I just want to understand what is physically happening in a situation like this.
I would have also thought that larger compounds would begin to settle on the bottom of the well on the refractometer, hence more solids would be on the interface, changing the reading...
Thanks again for your help
Toby
Proteins are at most several nm in size. Typical wavelengths used in (visible) optics is around 500 nm. Proteins are essentially point particles for visible light.
You are dealing with a instrument that measures a macroscopic material property- be careful trying to extrapolate to a microscopic description.
24K
  • · Replies 21 ·
