Projectile Motion Homework: Calculating Net Height for Daredevil Cannon Launch
The problem involves projectile motion, specifically calculating the height at which a net should be placed to catch a daredevil launched from a cannon at a 45-degree angle with a given initial speed. The scenario includes parameters such as horizontal distance and initial velocity.
  • The original poster attempts to use a specific equation related to projectile motion but indicates that it did not yield the expected result. Another participant suggests a different equation for calculating the height based on projectile motion principles.
The discussion is ongoing, with participants exploring different equations and approaches to the problem. There is a request for clarification on the original poster's attempt, indicating a desire for deeper understanding rather than a straightforward solution.
The original poster mentions an expected answer, which may influence the assumptions being made about the problem setup. There is also a note about a complete solution being removed, which may affect the flow of the discussion.
ssalem2
A daredevil is shot out of a cannon at 45degrees horizontal with an initial speed of 25.0m/s. A net is positioned at a horizontal distance of 50m from the cannon from which it is shot. At what height above the cannon should the net be placed in order to catch the daredevil?
P=X/ViCos(theta)
i tried this equation but it did not work out. The answer is supposed to be 10.8m. Please explain it if you get this correct. Thank you!
try this equation y = F(x): = yo +xTAN[tex]\theta[/tex] - gx2/2Vo2COS2[tex]\theta[/tex]
Complete Solution Removed
unscientific, please check your PM's.
  • · Replies 19 ·
28K
