Solve Electromag Question: Find V(x) from p Expression
  • Thread starter Thread starter coffeem
The discussion focuses on solving for the potential V(x) in an electron beam scenario, where the charge density p is given by the equation p = - (4ε₀V₀)/(9s^(4/3)x^(2/3)). The solution involves applying Poisson's equation, which simplifies the problem to finding V(x) as a function of x. The key takeaway is that using the relationship divE = p/ε₀ leads to an ordinary differential equation that can be solved to determine V(x) in the form V(x) = V₀s^p.x^q.
  • Understanding of electrostatics and electric fields
  • Familiarity with Poisson's equation in electrostatics
  • Knowledge of differential equations
  • Basic concepts of charge density and potential in electric fields
  • Study Poisson's equation and its applications in electrostatics
  • Learn about solving ordinary differential equations (ODEs)
  • Explore the relationship between electric fields and potential
  • Investigate charge density distributions in electromagnetic theory
Students and professionals in physics, particularly those focusing on electromagnetism and electrostatics, as well as anyone looking to deepen their understanding of potential and charge density relationships in electric fields.
coffeem
An electron beam with negligible velocity in the x direction is emitted from a heated plane cathode through a vacuum towards a plane anode at x = s, there the potential is V = Vo. At the cathode V(x) = 0 and x = 0. The charge density of the beam is;
p = - (4eoVo)/(9s^(4/3)x^2/3
Show that V(x) takes the form V(x) = Vos^p.x^q
I have worked out that I have to use: divE = p/e0
So when I substitute the expression I have for p into this I ger:
divE = (4Vo)/(9s^(4/3)x^2/3
However I do not know how to get this into a form to find V(x), I am stuck. Would appretiate some helpful hints or even something a bit more forceful. Thanks
Using Poisson's equation is a much easier way to go here...since V is a function of x only, [tex]\nabla ^2V= \frac{d^2V(x)}{dx^2}[/tex] and so applying Possion's equation gives you an ordinary differential equation which you can solve...try it and see what you get.
