| Thread Closed |
Finding tangent lines to an ellipse that pass through a given point |
Share Thread | Thread Tools |
| Nov19-08, 12:07 AM | #1 |
Find the equations of all the tangent lines to x^2 + 4y^2 = 36 that pass through the point (12,3) 2. Relevant equations the derivative of the ellipse is dy/dx = -2x/8y (I'm not sure if that is correct, i have only recently learned implicit differentiation.) 3. The attempt at a solution Using a point on the ellipse as ( x , +- ((6 - x) /2)) and the point which was given, i used the slope formula for a line and then set that equal to the derivative. However, now i'm left with 2 variables, x and y. I am 100% positive that we aren't suppose to use a CAS to solve this question. Could someone please help me out
| Nov19-08, 12:17 AM | #2 |
Mentor
Your equation for y at a point on the ellipse is wrong. The square root of (36 - x^2)/4 is not equal to (6 - x)/2.
I drew a quick sketch of the ellipse and found that its vertices are at (0, +/-3) and at (+/-6, 0). One of the tangent lines is horizontal. |
| Nov19-08, 12:21 AM | #3 |
then a point on the ellipse would be (x , root of (36 - x^2)/4 ) correct?. but even then wouldn't that leave me with the same problem when i set m = m
| Nov19-08, 12:58 AM | #4 |
Mentor
Any point on the ellipse is (x, +/-sqrt((36 - x^2)/4).
The equation of the line is [tex] -\frac{\sqrt{36 - x^2}}{2} - 3 = \frac{x}{2\sqrt{36 - x^2}}(x - 12)[/tex] For the first expression on the left side, I chose the negative root, since I want a negative y value at the point of tangency in the fourth quadrant. Multiply both sides by the expression in the denominator on the right side. [tex]-(36 - x^2) - 6\sqrt{36 - x^2} = x^2 - 12x[/tex] Now move everything but the radical to the other side. [tex] - 6\sqrt{36 - x^2} = - 12x + 36[/tex] Simplify a bit. [tex] \sqrt{36 - x^2} = 2x - 6[/tex] Square both sides. [tex]36 - x^2 = 4x^2 - 24x + 36[/tex] [tex]5x^2 - 24x = 0[/tex] The last expression on the left side can be factored to give the x-values that are on the line, and that have the right slope. As it turned out, I didn't need to be concerned about using a negative expression for the y-value in the 4th quadrant, because I squared both sides later on. You do need to take into account that the y-value is negative at one point of tangency, though. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Finding tangent lines to an ellipse that pass through a given point
| Tangent lines to an ellipse. | Calculus & Beyond Homework | 17 | ||
| How can I find the equation of tangent lines from a circle to point A? | Calculus & Beyond Homework | 21 | ||
| Coordinates at which 2 tangent lines of a function pass through a single point | Calculus | 4 | ||
| I need help on Finding the tangent of the ellipse | Calculus & Beyond Homework | 8 | ||
| conceptualizing two tangent lines to an ellipse | Introductory Physics Homework | 14 | ||
