The Benefits of Using Safety Wire for Secured Fasteners
  • Context: High School
  • Thread starter Thread starter AME2
    Safety Wire
The discussion revolves around the use of safety wire for securing fasteners, focusing on the benefits of twisting the wire between points. Participants explore various aspects of safety wire application, including its efficiency, the reasoning behind specific twisting techniques, and the implications of different methods in practical scenarios.
  • Some participants propose that the twist in safety wire retains tension, preventing loosening of fasteners.
  • Others mention that a long single loop could stretch and allow loosening, suggesting that twisting is beneficial.
  • One participant questions whether wire without a twist would be equally efficient, indicating uncertainty about the necessity of the twist.
  • Another participant notes that the direction of the twist may vary depending on the configuration of the bolts and torque applied, suggesting that both clockwise and counterclockwise twists can be valid.
  • Some participants discuss the historical context of the "left over right" rule, with differing opinions on its relevance and necessity.
  • A participant asserts that twisting the wire does not necessarily make it stronger and could potentially weaken it at its weakest point.
  • There is mention of specific guidelines (AC 43.13-1B) that provide context for safety wire practices, but interpretations of these guidelines vary among participants.
Participants express differing views on the necessity and implications of twisting safety wire, with no clear consensus on whether the twist is essential or if it affects the strength of the wire. The discussion remains unresolved regarding the best practices for safety wire application.
Participants reference specific guidelines and personal experiences, but there are unresolved questions about the physics of twisting and its impact on wire strength. The discussion also highlights varying interpretations of safety wire application rules.
AME2
I have a question about safety wire. Safety wire is used to secure fastners to prevent them from loosening. What are the benefits of the twist in the wire between points?
Here is a explanation of safety wire."[URL
http://en.wikipedia.org/wiki/safety_wire
I read but don't see a clear picture. perhaps a better view point?
Welcome to PF, AME2.
The twist is primarily to retain tension in the wire. If a long single loop was used between bolts, it could stretch enough to allow loosening.
As a side benefit, in non-official applications, the act of twisting can weed out a substandard wire because it will break during application.
I understand the side benefit.
Would the wire with no twist be just as efficient? I do not understand the loop and why left over right when you safety wire.
To the first question, no. To the second, I was totally unaware of any such requirement. It's probably just because a right-hander made the rules. (I can't see that it has any correlation with the bound bolts being right-hand threaded, since the wire merely suppresses rotation.)
That is an excellent link, Nucleus. I've bookmarked it for future reference. :approve:
I still didn't see anything about having to twist clockwise, though, other than the illustrations showing that. That leads me to think that the automatic twisting pliers do it, but that it might not be necessary for hand-twisting.
Danger
If you look at the examples with three bolts lock wired together. The direction of twist from the second to the third unit is counterclockwise on some of them. It comes down to where the bolts ended up after torque. It is wired counterclockwise in order to keep the loop in position against the head of the bolt and on others it is wired clockwise for the same reason. Also on the final pigtail is the same rules apply.
So the twist is really both ways – it just makes it look better. There are also lock wire pliers that are reversible or you can do it by hand.
This is covered in AC 43.13-1B Top of Page 7-23.
I see that now. Thanks again for clarifying things.
When I was taught how to safety wire I remember being told that it was indeed left over right. It has to do with the fact that 99% of the fasteners will loosen going in the counter clockwise direction which could cause a right over left twist to unravel and allow the single loop to pass over the top of the nut/bolt.
Indeed, that does explain it. Thanks nucleus
So the double-twist method is used to secure the wire around the bolt head. I also see the clockwise and counterclockwise reasons. Depending on which side of the bolt your on, you want the loop on the bolt head to remain in place by using the other wire as a block (to prevent the loop from rising up over the bolthead)
I guess the left over right rule is kinda out? I would'nt think the wire would come undone unless the wire broke.
No, as far as I know, the twist in the safety wire does not make it stronger. And it can only be as strong as it's weakest point, which would be the single wire through the bolt head. Twisting the wire weakens it.
I was thinking there might be some physics involved here that I was missing. Seems simple enough now.
sometimes you do want to sweat the small stuff.
  • · Replies 50 ·
10K
  • · Replies 29 ·
13K
  • · Replies 16 ·
  • · Replies 42 ·
  • · Replies 24 ·
  • · Replies 21 ·
  • · Replies 41 ·
