A few questions relating to the cross product
This discussion focuses on vector mathematics, specifically addressing the shortest distance between two cities represented as position vectors on a spherical Earth, the conditions for perpendicular vectors, and the criteria for parallel vectors. The shortest distance can be calculated using the formula for arc length, which is the product of the radius and the angle in radians. The proof for perpendicularity is established by squaring both sides of the equation |A+B| = |A-B|. Additionally, it is confirmed that two vectors A and B are parallel if their cross product AxB equals zero.
  • Understanding of vector mathematics
  • Familiarity with spherical geometry
  • Knowledge of trigonometric functions
  • Ability to manipulate algebraic expressions
  • Learn how to calculate arc length on a sphere using the formula arc-length = radius × angle (in radians)
  • Study the properties of vector addition and subtraction in relation to geometric interpretations
  • Explore proofs involving vector perpendicularity and parallelism
  • Investigate the applications of cross products in physics and engineering
Students studying vector mathematics, educators teaching geometry and trigonometry, and professionals in fields requiring spatial analysis and vector calculations.
Spiffy
Ug. My first try at this and my whole post was deleted. Here goes again :)
i) Two cities on the surface of the Earth are represented by position vectors that connect the location of each city to the centre of the earth. Assuming that the centre of the Earth is assigned the coordinates of the origin, and that the Earth is a perfect sphere, outline the steps that would lead to a calculation of the shortest distance between the two cities. Hint: How can you determine arc length?
ii) Prove A is perpendicular to B if |A+B| = |A-B|
iii) A||B if AxB=0
i) well you have two vectors pointing outword tail to tail and an angle Θ in between them. What I don't really know is how to find the arc length as the hint wants me to. If someone could point me toward an equation i'll report with some progress
ii) It seems so obvious that I'm sure it's staring me in the face and I don't even know it. I have drawn on my paper A vector downward and B and -B vector going on at 90o degrees either way. So now I have one triangle made up of two others and the two triangles are obviously equal to each other, they share adj and opp sidelengths and therefore the hypotenuse must as well be equal in both. I don't kknow how to take this from my sketch to something a bit more formal and algebraic though..
iii) I know that its true because if they were parallel sinΘ would = 0. I have:
AxB = |A||B|sinΘ
If A and B are parallel Θ=0
RS: |A||B|sin0
= 0
therefore AxB=0 when A and B are paralell. Would you accept this?
I appreciate any light that can be shed on some of these questions. I know this website is going to be a valuable resource for myself now and in the future. Even just typing questions up here is helping. (I originally had 4 questions but solved one just by putting it into a different form of media) thanks a lot!
Welcome to PF!
i) … Hint: How can you determine arc length?
iii) A||B if AxB=0
Ug! Welcome to PF! :smile:
i) arc-length = radius times angle (in radians)
(so arc-length for 2π angle is 2πr, as you'd expect! :wink:)​
ii) Hint: square each side!
iii) Your answer looks fine to me! :smile:
Yes, sometimes rewriting a question so that other people can understand it makes all the difference! :biggrin:
Ooog!
9K
  • · Replies 32 ·
