Proving the Field Property of a Group of Numbers
  • Thread starter Thread starter transgalactic
    Field
The discussion revolves around proving that a specific group of numbers forms a field. Participants are exploring the necessary properties and definitions related to fields, including closure under addition and multiplication, the existence of multiplicative inverses, and the structure of the set in question.
  • Participants discuss whether certain expressions remain within the set defined by the group of numbers, questioning how to construct proofs without variable inputs. There are inquiries about the definitions of fields and rings, and how to demonstrate closure under operations and the existence of inverses.
Several participants have provided insights into the requirements for proving the field property, including the need to show closure under addition and multiplication, as well as the existence of inverses. There is ongoing exploration of how to express elements of the set and whether certain operations yield results within the same set.
Some participants express uncertainty about the definitions of fields and rings, highlighting the importance of precise mathematical language. There is also mention of specific examples and hints provided by others in the thread, indicating a collaborative effort to clarify concepts.
transgalactic
i got this group of numbers
http://img205.imageshack.us/img205/5291/20039746rf4.gif
prove that its a field
A field must be closed under addition and multiplication and every non-zero number must have a multiplicative inverse.
Is (a+ b\sqrt{5})+ (c+ d\sqrt{5}) in that same set?
Is (a+ b\sqrt{5})(c+ d\sqrt{5}) in that same set?
Is \frac{1}{a+b\sqrt{5}} in that same set? (Hint: rationalize the denominator.)
the problem is that i remember these proofs as
Q(x)+Q(y)=Q(x+y)
Q(x)*Q(y)=Q(x*y)
but here the input the root of 5 instead of sum variable
i don't know how to construct these equations because there is no variable input?
Halls has shown you what you need to do. It seems pretty clear to me.
i clearly remember building these equations:
Q(x)+Q(y)=Q(x+y)
Q(x)*Q(y)=Q(x*y)
but in my function there is no variable in the input
Q(x)+Q(y)=Q(x+y)
Q(x)*Q(y)=Q(x*y)
What is a field, you probbably already know. However, In order to show that it is a ring, alll we need to show is that it is closed under subtraction, and under multiplication. Like Halls already told you.
What you are doing there, is basically a hommomorphism, that is the perservation of the operation, but we are not dealing with mapps between two fields in here.
So let x, and y be any two elements on that set, then obviously they will have the form
x=(a+ b\sqrt{5}); y= (c+ d\sqrt{5})
so
x-y=(a+ b\sqrt{5})- (c+ d\sqrt{5})=(a-c)+(b-d)\sqrt{5} so x-y \in Q(\sqrt{5})
now also
xy=(a+ b\sqrt{5})(c+ d\sqrt{5})=ac+ad\sqrt{5}+bc\sqrt{5}+bd5=(ac+bd5)+(ad+bc)\sqrt{5}[/itex] which again, for obvious reasons is in Q(\sqrt{5}) <br /> <br /> Now,in order for that to be a field, like Halls already stated,we need to show that every el. in that set has an inverse.<br /> <br /> let x be in that set. so it will obviously have the form =x(a+ b\sqrt{5}) let<br /> s suppose that there is another el, y, such that<br /> <br /> xy=1 =&amp;gt; y=\frac{1}{x}=\frac{1}{a+b\sqrt{5}}=\frac{a-b\sqrt{5}}{a^2-5b^2} SO, the same question still holds, is this in the same set?<br /> <br /> I&#039;ll give u one more hint: rewrite the last expression as<br /> <br /> \frac{a}{a^2-5b^2}+\frac{-b}{a^2-5b^2}\sqrt{5}
you don't need to construct these, because you are not dealing with a mapping between two rings or fields, and thus you are not asked to show whether that kind of mapping is a homomorphism. because, those expressions are used when we want to show that a particular mapping say between two rings is a homomorphism.
you meant under subtraction here, right?
yes if we split it:
a/(a^2-5b^2) -(b/a^2-5b^2)*5^(1/2)
is that correct?
transgalactic said:
yes if we split it:
is that correct?
Well, now the problem breaks down into showing whether
\frac{a}{a^2-5b^2}\in Q; and\frac{-b}{a^2-5b^2}\in Q ?
You can either prove this one too, or take it for granted. since a, b are rational nr. then by adding, subtracting, multiplying, and dividing them, we will still end up having rational numbers.
hallsofIvy said to prove that that inverse of the formula is of the same set
and
a/(a^2-5b^2) -(b/a^2-5b^2)*5^(1/2) => a/(a^2-5b^2) +(-b/a^2+5b^2)*5^(1/2)
its of the same set now(it looks like the original formula)?
how to prove that 0 or 1 are members
If you want to write 0 or 1 as "a+ b\sqrt{5}", what would a and b be equal to?
0=0+0\sqrt{5}, 1=1+0\sqrt{5} fair enough!
P.S this is what Halls already said!...lol...
how to recognize a ring proof
and field prove
i can't see the difference between them?
what is the form of a field?
what is the form of a ring?
(how each of their formula looks?)
and field prove
What are the definitions of "field" and "ring"?
ring is like x=(a+b,c,g+1)
and i need to
prove that it stays the same type by addition
and multiplication by scalar
and existence of zero.
field is like a formula
f(7)=a+7*b
is this correct
and i need to
f(7)=a+7*b
is this correct
Read the wiki article I linked, what you wrote is not very mathematical in nature i.e. a field is definitely not "like a formula f(7) = a + 7*b". These are pretty advanced mathematical ideas and you should have at the very least the definition of each ingrained in your brain before you go out and try to prove things about them.
and i need to
f(7)=a+7*b
is this correct
"ring is like" is not a DEFINITION. It is very important to learn the precise words of mathematical definitions. Definitions in mathematics are "working" definitions- you use the precise words of the definitions in proofs and problems.
A "ring" is a set of objects together with two binary operations, + and *, such that:
1) The set with the operation + is an abelian group (so you need to know the definition of that!).
2) The associative law is true for *, a*(b*c)= (a*b)*c and the distributive law a*(b+c)= a*b+ a*c is true.
A "field" is a set of objects together with two binary operations, + and *, such that:
1) The set with the operation + is an abelian group.
2) The associative law is true for * and the distributive law is true.
3) There exist an "identity" for *: a*1= 1*a= a for all a in the set.
4) Every element of the set except the additive identity has a multiplicative inverse.
(3) and (4) are, of course, the difference between a ring and a field. The set of all two by two matrices over the real numbers is an example of a ring (with identity) that is not a field. Some non-zero matrices do not have inverses.
regarding what you said about the field:
i remember you said that in order to prove a field
i need to prove that the sum and multiplication is of the same
structure.
and that the inverse is of the same structure
and that 0 exist
is that the tests i need to perform
Halls just outlined what you need to prove. Aren't you missing a few points?
Should we also explicitly mention that it is closed under the second operation * ? i.e fo every two el. a,b from the ring R, a*b is also in the ring.
This is somehow clear since the associative law is true, but the book from which i learned these things stated it explicitly as well. So, i think it is important to state it, especially since when you want to prove that something is a subring of a ring R, then all u need to prove is that it is closed under subtraction, and multiplication.
structure.
and that 0 exist
I know for which post you are talking about, but this isn't exactly the same situation, since in that case we only needed to prove that Q is a subring. So, we already knew that it is a set of a ring. I really think you should go back and read these things, because if you are having trouble with the definition of things, i cannot immagine how you can even think about starting to prove stuff.
