Find torque required to lift a mass
  • Thread starter Thread starter vladimir69
    Lift Mass Torque
The discussion revolves around calculating the torque required by a crane's engine to lift a weight using a drum and pulley system. The problem involves understanding the dynamics of rotational motion, specifically how the mass of the drum and pulley, along with the tension in the cable, influences the torque needed to achieve a specified acceleration.
  • Mixed
  • Participants explore various equations related to torque, moment of inertia, and angular acceleration. There are attempts to relate the tensions in the rope segments and how they affect the net torque on both the pulley and the drum.
Several participants are actively working through the problem, with some expressing uncertainty about the relationships between the different forces and torques involved. There is recognition that the tension in the rope is not uniform and that the engine's contribution to torque must be considered. Guidance has been offered regarding setting up equations for net torque.
Participants note the complexity of the problem due to multiple torques acting on the system and the need to account for friction and varying tensions in the rope. There is also mention of a formatting issue with the display of equations in the forum.
vladimir69
A crane contains a hollow drum of mass 150kg and radius 0.8m that is driven by an engine to wind up a cable. The cable passes over a solid cylindrical 30kg pulley 0.3m in radius to lift a 2000N weight. How much torque must the engine apply to the drum to lift the weight with an acceleration of 1ms^(-2)
As I am only currently dealing with 1D rotationl motion the equations are
[tex]\tau=FR\sin\theta[/tex] where i suppose theta is 90 degrees
[tex]\tau=I\alpha[/tex]
[tex]a_{t}=\alpha R[/tex]
[tex]I_{pulley} = \frac{1}{2}M_{p}R_{p}^2[/tex]
[tex]I_{drum} = M_{d}R_{d}^2[/tex]
[tex]F=ma_{t}[/tex]
The difficulty I have with this question is the pulley and drum. I'm not sure how to factor both of these in and not sure where the mass comes into the overall scheme of things either, though I'm sure its got something to do with it.
Now I know
[tex]I_{pulley} = \frac{1}{2} \times 30 \times 0.3^2 = 1.35 kg m^2[/tex]
[tex]I_{drum} = 150 \times 0.8^2 = 96 kg m^2[/tex]
[tex]m = \frac{2000}{9.8} = 204.1kg[/tex]
The tension in the rope between the pulley and the mass is given by
[tex]T-mg=ma[/tex] where [tex]a = 1ms^-2[/tex] so
[tex]T = mg+ma = 2204.1N[/tex]
This is where things become unclear, after this I am just guessing
[tex]\tau_{pulley} = T R_{pulley} = 2204.1 \times 0.3 = 661.23Nm[/tex]
assuming tension in rope is the same between drum and pulley then
[tex]\tau_{drum} = T R_{drum} = 2204.1 \times 0.8 = 1763.28Nm[/tex]
or perhaps
[tex]\tau_{pulley} = I_{pulley} \alpha = I_{pulley} \frac{a_{t}}{R_p}=1.35 \times \frac{1}{0.3}=4.5Nm[/tex]
I am out of ideas after this point.
answer in back of book = 1900Nm
Thanks,
vladimir
More than one torque is acting on the drum. So think in terms of net torque and angular acceleration, just like you do with force and linear acceleration.
... assuming tension in rope is the same between drum and pulley ...
Actually, it isn't. The rope exerts a torque on the pulley due to friction. This is the torque that causes the pulley rotation to accelerate. Likewise (Newton's 3rd Law), the pulley exerts a force on the rope, changing the tension value before & after the pulley.
still not sure how to go about it
The only guess I could make is that (assuming that the entire rope is accelerating at the same rate of [tex]1ms^{-2}[/tex]
[tex] \tau_{net} = \tau_{drum} + \tau_{pulley} [/tex]
which leads to about 3 possibilities I can think of
we can do
[tex] \tau_{net} = M_{drum} R_{drum}^2 \alpha_{drum} + \frac{1}{2}M_{pulley}R_{pulley}^2 \alpha_{pulley} = 124.5Nm[/tex]
where [tex]\alpha_{drum}=\frac{1}{R_{drum}}[/tex] and [tex]\alpha_{pulley}=\frac{1}{R_{pulley}}[/tex]
or
[tex] \tau_{net} = M_{drum} R_{drum}^2 \alpha_{drum} + TR_{pulley} = 781Nm[/tex]
or even
[tex] \tau_{net} = T R_{drum} + \frac{1}{2}M_{pulley}R_{pulley}^2 \alpha_{pulley} = 1767Nm[/tex]
None of the above arrives at the right answer but they are only guesses. My first guess makes the most sense to me, however it is wrong.
By the way, does anyone know how to get rid of that white ... out of the tex equations?
I'm not sure which object this taunet refers to? It almost sounds like it's for the rope, but that doesn't make any sense since the rope is not rotating.
We are trying to set up a
. . torquenet = I * alpha
equation for the drum, to answer the question.
To do that, we need the tension in the rope at the drum. Since the rope provides a net torque on the pulley, we'll need to set up
for the pulley.
So, draw a free body diagram for the pulley. Hint: think of the rope as exerting two forces, in different directions, on the pulley. One force is from the weight-to-pulley section of rope, the 2nd force is from the pulley-to-drum section of rope. They have different tensions; solve the equation for the pulley-to-drum tension.
It's a bug, and unfortunately there's nothing members like us can do to get rid of it. The forum administrators are aware of the problem, but I guess it's not an easy one to fix.
ok here goes another try
let [tex]T_{1}[/tex] be the tension in the rope between the drum and the pulley
let [tex]T_{2}[/tex] be the tension in the rope between the pulley and the mass
so using Mr Newton on the 2000N mass
[tex]T_{2} - 2000 = ma = 204.1 \times 1[/tex]
[tex]T_{2} = 2204.1[/tex]
now for the net torque on the pulley
[tex]\tau_{net} = (T_{1} - T_{2}) R_{p} = I_{p} \alpha_{p}[/tex]
so
[tex]T_{1} = \frac{I_{p}\alpha_{p}}{R_{p}} + T_{2}= \frac{\frac{1}{2}M_{p} R_{p}^2\alpha_{p}}{R_{p}} + T_{2}=\frac{1}{2}M_{p}R_{p}\alpha_{p}+T_{2}[/tex]
now I shall take [tex]a_{t} = 1ms^{-2}[/tex] so [tex]\alpha_{p} = \frac{1}{R_{p}}[/tex]
which gives
[tex]T_{1} = \frac{1}{2}M_{p} + T_{2}=15+2204.1=2219.1N[/tex]
now the net torque on the drum is
[tex]\tau_{net} = T_{1} R_{d} = 2219.1N \times 0.8m = 1775Nm[/tex]
which is wrong.
Not sure where the [tex]I\alpha[/tex] thing comes into it for the net torque of the drum. I suppose it must pop in somewhere because my answer doesn't depend on the mass of the drum
You're very close!
The question being asked is
How much torque must the engine apply to the drum ...
In other words, there's an engine and it contributes to the net torque on the drum.
Set up a torquenet = I * alpha equation for the drum, similar to what you did for the pulley.
ok i think i have finally got it
heres a quick sketch of what i did
[tex]T_{2} - mg = ma[/tex]
net torque of pulley:
[tex] \tau_{net} = (T_{1} - T_{2}) R_{p} = \frac{1}{2}M_{p}R_{p}^2\alpha_{p}[/tex]
[tex]T_{1} = \frac{1}{2}M_{p}+T_{2}[/tex]
net torque of drum:
[tex] \tau_{net} = (F_{engine} - T_{1}) R_{d} = M_{d}R_{d}^2\alpha_{d}[/tex]
[tex]F_{engine} = M_{d}+T_{1}[/tex]
torque required by engine
[tex]\tau_{engine} = F_{engine} R_{drum}<br /> which gave me about 1895Nm<br /> <br /> thanks for your help Redbelly98<br /> greatly appreciated, would never have solved it without your help[/tex]
Looks pretty good. There are a couple of "R" terms missing, don't know if you just forgot about them in your post or they are missing from your written solution as well:
½ Mp → ½ Mp Rp
net torque of drum:
Similarly,
Md → Md Rd
Usually, checking the units (and explicitly including the 1/s2 angular acceleration) will catch little errors like that.
You're welcome!
  • · Replies 40 ·
  • · Replies 30 ·
  • · Replies 21 ·
