Double Integral Limits for a Sideways Rectangle
The discussion focuses on setting up double integral limits for a tilted rectangle defined by the vertices (1,0), (0,1), (2,3), and (3,2) while solving the integral of the function (ytan^-1(x) - 3). The problem involves using Green's theorem and transforming variables to u = y - x and v = y + x, resulting in integration limits of u from -1 to 1 and v from 1 to 5. Additionally, calculating the Jacobian is necessary for converting dxdy in this context.
  • Understanding of double integrals and their limits
  • Familiarity with Green's theorem
  • Knowledge of variable substitution in integrals
  • Ability to compute the Jacobian for variable transformations
  • Study the application of Green's theorem in solving double integrals
  • Learn about variable transformations in multiple integrals
  • Practice calculating Jacobians for various transformations
  • Explore examples of integrating over non-rectangular regions
Students and educators in calculus, particularly those focusing on multivariable calculus and integral calculus, as well as mathematicians interested in advanced integration techniques.
Moragor
I have to solve the integral of (ytan^-1(x) - 3) inside the area of the rectangle with vertices (1,0), (0,1), (2,3), (3,2). How do I set up these limits?
This is a tilted rectangle so I can't use just values for the limits?
This is a Green's theorem problem that started out as integral(tan^-1(x)dx + 3xdy). I just can't figure out the limits.
The parallel lines through (1,0), (3,2) and (0,1),(2,3) are y= x-1 and y= x+ 1, respectively; both are variations on "y-x= constant". The parallel lines through (1,0),(0,1) and (3,2),(2,3) are y= 1-x and y= 5-x, respectively; both are of the form "y+ x= constant. Changing variable to u= y- x and v= y+ x gives an integral with limits of integration in u of -1 to 1 and in v, 1 to 5. Be sure to calculate the Jacobian to convert dxdy.
Have you already calculated the integration around the boundary?
  • · Replies 17 ·
