What is the acceleration of the elevator?
The discussion revolves around calculating the acceleration of an elevator based on the tension in a string from which a suspended object is hanging. The subject area includes concepts from dynamics and forces.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between tension, gravitational force, and acceleration. There are attempts to incorporate the mass of the elevator into the calculations, and questions arise regarding the source of the mass value used.
The discussion is ongoing, with some participants affirming the reasoning behind the calculations while others seek clarification on the assumptions made, particularly regarding the mass of the elevator.
There is a noted ambiguity regarding the mass of the elevator and its relevance to the calculations, as well as the accuracy of the initial calculations presented.
Muteb
The tension on a string from which a 4.0 kg object is suspended in an elevator is equal to 44.0 Newton.
Is this answer rigth
44 N - (4.0 kg X 9.8) = a (4.5 + 4) I think the 4.5 is mass of elevator and 4 the mass of the object which is suspended.
Acceleration = 0.57 m/s^2
You're almost there. Why do you need to include the mass of the elevator and where do you pull that value of 4.5kg from?
I think this is ok now isn't it?
F=4.8N
F=ma
4.8kg*m/s^2=4kg*a
a=1.2m/s^2 [u
F=4.8N
F=ma
4.8kg*m/s^2=4kg*a
a=1.2m/s^2 [u
Looks good to me :approve:
  • · Replies 31 ·
