Prove that of sum square root of 2 and square root of 3 is not rational
The discussion revolves around proving that the sum of the square root of 2 and the square root of 3 is not a rational number. Participants explore the nature of irrational numbers and their sums, questioning whether the sum of two irrational numbers must also be irrational.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants suggest using proof by contradiction and the rational roots theorem to explore the properties of the sum of the two square roots. There are inquiries about the implications of having no rational roots for the derived equations.
Several participants are actively engaging with the problem, proposing different methods and questioning the assumptions involved. There is no explicit consensus on the approach, but productive lines of reasoning are being explored.
Some participants note that the lack of rational roots does not necessarily imply that the sum is irrational, raising the possibility of complex solutions. The discussion includes references to specific mathematical properties and theorems relevant to the problem.
transgalactic
prove that the square root of 2 plus the square root of 3 is not rational?
does always the sum of two not rational numbers is a not rational number?
i know the proof 2 = a^2/b^2
i separately proved that square root of 2 and square root of 3 are irrational
how two prove that the sum of two such numbers is irrational too?
whats the formal equation proof?
Try a proof by contradiction. Suppose that [tex]\sqrt{2} + \sqrt{3} = \frac{a}{b}[/tex]
where a and b are integers with no common factors.
For your second question [tex]\sqrt{5} + (-\sqrt{5}) = 0[/tex]
Those are both irrational numbers, but their sum is rational.
Well clearly two irrational numbers can sum to give a rational number. For example (2+sqrt(2)) + (2 -sqrt(2)).
To show that the sqrt(2) + sqrt(3) is irrational, you can start with
a = sqrt(2) + sqrt(3)
Manipulate to get
a^4 - 10a^2 + 1 = 0
Then you can use the rational roots theorem, that shows that the only rational roots of this equation can be +- 1. http://en.wikipedia.org/wiki/Rational_root_theorem
Somehow, that just seems like cheating, but it does fit the problem we were given.
Any mathematical statement can be disproved by a counterexample. The simpler the counterexample, the better.
ok i will try to prove by contradiction:
suppose
(2)^0.5 + (3)^0.5 is a rational number
(if we multiply a rational number by a rational number we will get a rational number "h")
5+2*(2)^0.5 * (3)^0.5=h
24=h^2 -10*h +25
h^2 -10*h +1=0
what to do now?
As I suggested earlier, make use of the rational roots theorem.
by this rational roots theorem
the possible roots is +1 and -1
not one of the represent the actual roots of h^2 -10*h +1=0
what is the next step in the prove?
What did you set out to do in your post #6?
You don't need anything but parity to prove this.
Prove
[tex]\sqrt{2}+\sqrt{3} = (p/q)[/tex]
[tex]2 \sqrt{6}+5 = p^{2}/q^{2}[/tex]
You know that the rationals form a field, which implies all the terms in the sum must be a rational.
Now all that remains is to show [tex]\sqrt{6}[/tex] is irrational. So just show that if it equals p/q, p and q must both be even.
suppose
24=h^2 -10*h +25
h^2 -10*h +1=0
what to do now?
the root test showed me that there is no rational roots for this equation.
is it fair to consider "h" irrational because of it?
i was told that if we don't have a rational roots it doesn't mean that
"h" is always irrational,"h" could be a complex number.
If a number is complex, it certainly isn't a rational number. If h^2 - 10h + 1 = 0 doesn't have any rational roots, then there is no solution for h that is rational.
you meant "irrational" (in the end) right?
I edited my reply. The last part should have said "there is no solution that is rational."
Manipulate to get
a^4 - 10a^2 + 1 = 0
how did you arrive at a^4 - 10a^2 + 1 = 0?
need help
Well since we've already summoned this thread from the grave...
need help
[tex]a=\sqrt{2}+\sqrt{3}[/tex]
[tex]a^2=(\sqrt{2}+\sqrt{3})^2=2+2\sqrt{2}\sqrt{3}+3=5+2\sqrt{6}[/tex]
[tex](a^2-5)^2=(2\sqrt{6})^2[/tex]
[tex]a^4-10a^2+25=24[/tex]
[tex]a^4-10a^2+1=0[/tex]
  • · Replies 22 ·
10K
