Determining Divergence or Convergence in Series
The forum discussion focuses on determining the convergence or divergence of the series \(\sum \frac{2n^{2}+3n}{\sqrt{5+n^{5}}}\) from \(n=1\) to infinity. The user attempted both the Ratio Test and the Limit Comparison Test but encountered inconsistencies in their results. The consensus suggests breaking the series into two parts: analyzing \(\sum \frac{2n^{2}}{\sqrt{5+n^{5}}}\) to establish convergence, as the second term \(\sum \frac{3n}{\sqrt{5+n^{5}}}\) is smaller and will not affect the overall convergence.
  • Understanding of series convergence tests, specifically the Ratio Test and Limit Comparison Test.
  • Familiarity with limits and asymptotic behavior of functions as \(n\) approaches infinity.
  • Knowledge of polynomial and radical expressions in calculus.
  • Ability to manipulate and simplify algebraic expressions for series analysis.
  • Study the application of the Ratio Test in greater detail, focusing on its limitations and conditions.
  • Learn about the Limit Comparison Test and its effectiveness in determining series convergence.
  • Explore techniques for breaking down complex series into simpler components for analysis.
  • Investigate the behavior of polynomial functions divided by radical expressions as \(n\) approaches infinity.
Students studying calculus, particularly those focusing on series convergence, as well as educators and tutors seeking to clarify convergence tests and their applications.
badirishluck
[tex]\sum[/tex] (2n[tex]^{2}[/tex]+3n)[tex]/\sqrt{5+n^{5}}[/tex]
index n=1 to infinity
I tried both the Ratio Test (limit as n goes to infinity of a[tex]_{n+1}[/tex][tex]/a_{n}[/tex]) and the Limit comparison test (limit as n goes to infinity of [tex]a_{n}[/tex]/ [tex]b_{n}[/tex]) but wasn't able to come up with the same answer from the two tests. What am I doing wrong?
Does it converge or diverge? How?
try breaking it into 2 pieces and see what you can do with the individual pieces, see if
[tex]\sum[/tex] (2n[tex]^{2}[/tex])[tex]/\sqrt{5+n^{5}}[/tex]
converges, if it does then the whole thing does since the 2nd term is smaller, if it doesn't then the whole thing does not converge.
