[Q]Hamiltonian of many body problem.
  • Context: Graduate
  • Thread starter Thread starter good_phy
    Body
The Hamiltonian for a two-particle system is expressed as H = \frac{-\hbar^2}{2m}\frac{\partial^2}{\partial x_{1}} + \frac{-\hbar^2}{2m}\frac{\partial^2}{\partial x_{2}} + v(x). This formulation is valid for constructing Hamiltonians of many-body systems, but additional constraints apply based on particle indistinguishability, requiring symmetric or antisymmetric states for bosons and fermions, respectively. Computational methods can be employed after transforming the wave equation into matrix form, with specific approaches varying based on the potential's characteristics. Closed-form solutions are rare, necessitating the use of approximations such as the Born-Oppenheimer approximation for systems with disparate particle masses.
  • Understanding of Hamiltonian mechanics
  • Familiarity with quantum mechanics and wave functions
  • Knowledge of particle statistics (bosons and fermions)
  • Experience with computational methods in physics
  • Explore Hamiltonian mechanics in depth
  • Learn about the Born-Oppenheimer approximation
  • Study computational techniques for solving differential equations
  • Investigate the properties of bosons and fermions in quantum systems
Physicists, quantum mechanics students, computational physicists, and anyone involved in solving many-body problems in quantum systems.
good_phy
Hi
I thought Hamiltonian for two particle system is [itex]H = \frac{-\hbar^2}{2m}\frac{\partial}{\partial x_{1}} + \frac{-\hbar^2}{2m}\frac{\partial}{\partial x_{2}} + v(x)[/itex]
But is it right? I just want to know This way is right to construct every hamiltonian of many
body system.
What i want to know more is How can we solve this problem?
I have heard that computational methode can be used after transforming wave equation to
matrix form. Is it right?
Do you have any recommandation practice to improve integral and solve difficult differential
equation ?
First, I should say that the derivatives in your equation should be second derivatives, not first derivatives. Secondly, while you are correct that a general quantum mechanical system has the above form (derivative error aside), there are additional constraints imposed by the types of particles you are considering. If they are indistinguishable, the state of the system must be either symmetric or antisymmetric under exchange of the two particles (depending on whether they are bosons or fermions).
Obviously, if you want to solve the problem computationally, how you go about doing so will vary depending on the form of the potential. For example, if the two particles are weakly coupled, then you can get away with solving the individual particle wavefunctions and perturbatively adding back the coupling term. Or, if one particle is much heavier than the other (e.g., the hydrogen atom), the Born-Oppenheimer approximation would work nicely. In most cases, you won't find a nice closed-form solution, and some approximation is necessary.
  • · Replies 17 ·
