Solving Lagrange Multipliers for f(x,y)=x^{2}y
The discussion focuses on using Lagrange Multipliers to find the maximum and minimum values of the function f(x,y)=x²y under the constraint g(x,y)=x²+y²=1. Participants detail the gradient equations, leading to the system 2xy=2xλ and x²=2yλ. The conversation emphasizes the importance of avoiding division by variables, particularly when x=0, and suggests eliminating λ by manipulating the equations. This approach leads to a solvable system of equations for x and y.
  • Understanding of Lagrange Multipliers
  • Familiarity with gradient vectors
  • Basic knowledge of solving systems of equations
  • Concept of constraints in optimization problems
  • Study the method of Lagrange Multipliers in depth
  • Learn to manipulate and solve systems of equations
  • Explore examples of optimization problems with multiple constraints
  • Investigate the implications of critical points in multivariable calculus
Students and professionals in mathematics, particularly those studying calculus and optimization techniques, as well as anyone interested in applying Lagrange Multipliers to real-world problems.
SelHype
Use Lagrange Multipliers to find the maximum and minimum values of f(x,y)=x[tex]^{2}[/tex]y subject to the constraint g(x,y)=x[tex]^{2}[/tex]+y[tex]^{2}[/tex]=1.
[tex]\nabla[/tex]f=[tex]\lambda[/tex][tex]\nabla[/tex]g
[tex]\nabla[/tex]f=<2xy,x[tex]^{2}[/tex]>
[tex]\nabla[/tex]g=<2x,2y>
1: 2xy=2x[tex]\lambda[/tex] ends up being y=[tex]\lambda[/tex]
2: x[tex]^{2}[/tex]=2y[tex]\lambda[/tex] ends up being(1 into 2) x=[tex]\sqrt{2\lambda[/tex] ^{2}}[/tex]
3: x[tex]^{2}[/tex]+y[tex]^{2}[/tex]=1
1 and 2 into 3:
(2[tex]\lambda[/tex][tex]^{2}[/tex])+([tex]\lambda[/tex][tex]^{2}[/tex])=1
Do I then solve for [tex]\lambda[/tex] and x and y? Did I do the above correctly? I am going off of an example of f(x,y,z) so I'm not sure if I'm correct. Any help is greatly appreciated!
Be careful when dividing by a variable because x=0 could easily be a solution to this problem. Instead of trying to solve for lambda, try eliminating it. You could try multiplying the first equation by y and the second equation by x. You should get an equation for x and y, and so coupled with equation 3, you have two equations two unknowns.
  • · Replies 16 ·
  • · Replies 18 ·
