Simple harmonic motion and frequency; answer disagrees from answer key
The discussion centers on a physics problem involving simple harmonic motion of a block attached to a spring, oscillating between x = 10 cm and x = 50 cm with a period of 0.25 seconds. The correct amplitude is calculated as 20 cm, while the frequency is determined to be 4 Hz, contradicting the user's initial calculation of 2 Hz. The user misinterpreted the period by assuming it took 0.5 seconds to complete a full cycle, while the correct interpretation is that 0.25 seconds represents the time for half a cycle, leading to the correct frequency of 4 Hz as stated in option B of the answer choices.
  • Understanding of simple harmonic motion principles
  • Knowledge of oscillation amplitude and frequency calculations
  • Familiarity with the relationship between period and frequency (T = 1/f)
  • Basic skills in solving physics problems involving springs and oscillations
  • Study the concept of simple harmonic motion in more depth
  • Learn how to accurately calculate amplitude and frequency from motion limits
  • Review the relationship between period and frequency in oscillatory systems
  • Practice solving similar physics problems involving springs and oscillations
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to clarify concepts related to simple harmonic motion and frequency calculations.
clairez93
A block attached to a spring oscillates in simple harmonic motion along the x axis. The limits of its motion are x = 10 cm and x = 50 cm and it goes from one of these extremes to the other in 0.25 s. Its amplitude and frequency are:
A) 40 cm, 2 Hz
B) 20 cm, 4 Hz
C) 40 cm, 2 Hz
D) 25 cm, 4 Hz
E) 20 cm, 2 Hz
[tex]T = 1/f[/tex]
I got the amplitude correct by adding the limits and dividing by two to find the midpoint of the motion, which was 30 cm, which I took to be equilibrium. Then I subtracted 10 cm, one limit of motion, from 30 cm, equilibrium to get the amplitude of 20 cm.
The frequency is where I mess up. I multiplied .25s by 2, since I thought it takes .25 seconds to complete half the cycle; I thought it must go back to the same extreme to complete a cycle, and thus would take another .25s. I got .5s for the period and then took the reciprocal of .5 for a frequency of 2 Hz.
The answer key however says the answer is B, a frequency of 4 Hz. Is this a mistake of the answer key or on my part? I do not see why the frequency would be 4.
I'd say that you are correct and the answer key is wrong.
  • · Replies 51 ·
  • · Replies 18 ·
