How Do You Calculate Velocity in Relativity Without a Calculator?
  • Thread starter Thread starter edd0107
    Relativity
The discussion revolves around calculating velocity in the context of special relativity, specifically involving a scenario where a spaceship travels to a constellation 9 light years away, taking 12 years according to the travelers on the ship. Participants are exploring how to derive the velocity without the use of a calculator.
  • Participants discuss the basic formula for velocity (v=d/t) and its application to the problem. There are questions about the interpretation of the time spent traveling and whether it refers to the observers on Earth or the travelers on the spaceship. Some participants suggest using algebraic manipulation to account for time dilation effects without a calculator.
There is a mix of agreement and differing interpretations regarding the time reference for the 12 years. Some participants have provided algebraic approaches to the problem, indicating that multiple lines of reasoning are being explored. The discussion is ongoing, with participants seeking clarification and confirming assumptions.
Participants are navigating the constraints of not using a calculator and are questioning the definitions of proper time and time dilation in the context of the problem. The distinction between the perspectives of Earth observers and those aboard the spaceship is also under consideration.
edd0107
I know that the proper length from a person on Earth to a certain constellation is 9 light years and that the time spent traveling in a spaceship during a one-way trip to the constellation is 12 years. I have been asked to find the velocity and I have been told that I will not need to use a calculator. This has me a little stumped.
My thought is that v=d/t so v=9/12 and the velocity is .75c (c is of course the speed of light). That makes sense if I don't need a calculator. This is the only solution I can come up with.
Any comments, suggestions, or confirmation would be helpful?
Sounds good to me (assuming that the trip time of 12 years is according to Earth observers).
Can you use a pencil and paper, or are you supposed to find a way to solve it that doesn't even require you to solve any equations? If the ship travels at speed v, naturally the time taken in the Earth's frame will be 9/v. But because of time dilation, the time for the ship will be smaller than this be sqrt(1 - v^2/c^2), and if we're using units of light years and years c = 1 so the time according to the ship's clock will by a factor of (9/v)*sqrt(1 - v^2), and that gives us (9/v)*sqrt(1 - v^2) = 12. With a little algebra you can solve this for v without needing to use a calculator (although you have to remember your squares table). I get an answer which is different from 0.75c.
edd0107 said "the time spent traveling in a spaceship during a one-way trip to the constellation is 12 years", I assumed that to mean that the time was 12 years for the people aboard the ship.
You're right. (D'oh!) And that more interesting problem is also easily solved without a calculator.
  • · Replies 39 ·
  • · Replies 35 ·
  • · Replies 27 ·
