Calculating Air Column Length in a Capillary Tube Using Boyle's Law
The discussion focuses on calculating the length of an air column in a capillary tube using Boyle's Law. Given a sealed capillary tube with an initial air column length of 36 mm when horizontal, the problem involves determining the new length of the air column, denoted as x mm, when the tube is positioned vertically. Using the formula derived from Boyle's Law, the calculated length of the air column is x = 34.2 mm, based on the pressures of 760 mmHg and 800 mmHg.
  • Understanding of Boyle's Law (pV = constant)
  • Knowledge of pressure measurements in mmHg
  • Basic concepts of fluid mechanics
  • Familiarity with capillary action and its effects
  • Study the implications of Boyle's Law in different gas scenarios
  • Explore the relationship between pressure and volume in closed systems
  • Learn about capillary action and its applications in fluid dynamics
  • Investigate the effects of temperature on gas behavior
Students studying physics, particularly those focusing on gas laws and fluid mechanics, as well as educators seeking to explain practical applications of Boyle's Law.
Machodog
A uniform capillary tube (with one end sealed) contains air trapped by a mercury thread 40mm long. When the tube is placed horizontally, the length of the air column is 36 mm. When placed vertically, with the open end of the tube downwards, the length of air column is now x mm (the mercury is still 40mm).
Calculate x if the atmospheric pressure is 760 mmHg, assuming that the air obeys Boyle's law.
Boyle's law, pV = constant.
density = mass/volume perhaps?
I really have no clue how to start, any hints would be great.
The initial pressure of the air is 760 mm Hg. When placed vertically, the air pressure is 800 mm Hg. So the new length of the air column, according to Boyle's law is ##x=\frac{(760)(36)}{800}=34.2 mm##
17K
9K
  • · Replies 19 ·
