Thread Closed
Time it takes to fill a pool.
Share Thread Thread Tools
Nov27-08, 01:58 AM   #1
To fill a child's inflatable wading pool you use a garden hose with a diameter of 2.8 cm. Water flows from this hose with a speed of 1.1 m/s. How long will it take to fill the pool to a depth of 32 cm if it is circular and has a diameter of 2.7 m?
2. Relevant equations
delta m=p1 A1 v1 delta t
(p=density, A=area, v=velocity, t=time)
A1 v1=A2 v2
Q=A v
idk if there is another equation that deals with time, i can't find any.
3. The attempt at a solution
since everything is dealing with water, i didn't really consider density.
the amount of water needed:
V= pi r^2 h=pi (1.35)^2 (.32)= 1.83 m^3
the area of the hose is:
A= pi r^2= pi (.014)^2= 6.16e-4 m^2
Q=A v=6.16e-4 (1.1)=6.78e-4 m^3/s
mass flow rate= .6776 kg/s
i don't really know where to go from here...
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Nov27-08, 02:11 AM   #2
first, your volume of pool measurement is a little wrong. You've used the diameter as a radius in your equqtion.
You've also made the sam mistake in calculating the cross sectional area of the hose.
delta m over delta t will give you your mass flow rate. But you need your volumetric flow rate. so how do you turn mass in a volume (hint: pensity is required)
keep trying and le tme know.
Nov27-08, 02:12 AM   #3
my typing is terrible this morning, sorry for the spelling mistakes. going to get some more coffee
Nov27-08, 02:35 AM   #4
Quote by redargon View Post
i fixed the problems and hopefully they are right. i found the mass flow rate and also the volumetric flow rate. we haven't learned about pensity in our class yet...so there has to be a different way.
Nov27-08, 02:37 AM   #5
i figured it out. thanks :)
Nov27-08, 03:23 AM   #6
pensity was a spelling mistake for density, sorry. Glad you got it, no prob.
Thread Closed
Thread Tools
Similar Threads for: Time it takes to fill a pool.
Thread Forum Replies
Time it takes to hit the ground Introductory Physics Homework 2
Finding the time it takes to stop Introductory Physics Homework 2
A real big toughie. Takes some time. Brain Teasers 1
Time it takes for an object to hit the ground Introductory Physics Homework 5
time it takes to reach equilibrium Classical Physics 7
