Is Every Projection Map a Quotient Map in Topology?
A projection map f:X-->X/~, defined by f(x)=[x], is onto and maps equivalent classes to their representatives. A quotient map p:X-->Y is characterized by the property that a subset U is open/closed in Y if and only if its preimage under p is open/closed in X. The discussion confirms that while every projection can be a quotient map, it is contingent upon the topology defined on X/~. Specifically, the quotient topology must be induced by f for the projection to be continuous.
  • Understanding of topological spaces
  • Familiarity with equivalence relations
  • Knowledge of quotient topology
  • Basic concepts of continuity in topology
  • Study the properties of quotient maps in topology
  • Learn about the construction of quotient topologies
  • Explore examples of non-continuous maps in topology
  • Investigate the implications of different topologies on the same set
Mathematicians, particularly those specializing in topology, educators teaching advanced mathematics, and students seeking a deeper understanding of projection and quotient maps.
math8
Is a projection a quotient map?
I think a quotient map is an onto map p:X-->Y (where X and Y are topological spaces) such that
U is open/closed in Y iff (p)-1(U) is open/closed in X.
And a projection is a map f:X-->X/~ defined by f(x)=[x] where [x] is the equivalent class (for a relation ~) containing x.
I guess a projection is onto because for every equivalent class [x], there is an x that maps to it, but I am wondering if every projection is a quotient map (or if every projection is continuous).
Hi Math8,
In order to talk about whether your projection map is continuous, you need to have defined what the open sets in X/~ are. The standard procedure is to define the topology on X/~ to be the so-called quotient topology induced by f. That is, so that f is a quotient map; i.e., a set U in X/~ is open iff f^(-1)(U) is open in X.
Of course, one can invent a topology on X/~ so that f is not continuous. Say, partition the plane X=R2 into a closed half-plane and an open half-plane. Then X/~ has two points X1 and X2, where [tex]f^{-1}(X_1)[/tex] is a closed-half-plane, and [tex]f^{-1}(X_2)[/tex] is an open half-plane. Define the topology on X/~ to be the discrete one, so X1 and X2 are open, and f is not continuous as [tex]f^{-1}(X_1)[/tex] is not open in R2.
