Prove two metric spaces have the same open balls
  • Thread starter Thread starter winter85
    Balls Metric
The discussion centers on proving that the metric spaces (X, d) and (X, d₁) have the same open sets, where d₁(x,y) = d(x,y)/(1 + d(x,y)). The proof demonstrates that for any open ball S(x) in (X, d) with radius r, there exists a corresponding open ball S'(x) in (X, d₁) with radius r/(1 + r), establishing that S(x) = S'(x). The only exception noted is when the radius is infinite, which cannot be represented in the d₁ metric. The continuity and monotonicity of the function f(x) = x/(1+x) are crucial in this argument.
  • Understanding of metric spaces and their properties
  • Familiarity with continuous functions and monotonicity
  • Knowledge of open sets and open balls in topology
  • Basic grasp of limits and intervals in real analysis
  • Study the properties of continuous functions in metric spaces
  • Learn about the concept of compactness in metric spaces
  • Explore the implications of different metrics on the same set
  • Investigate the role of open and closed sets in topology
Mathematics students, particularly those studying topology and analysis, as well as educators seeking to clarify concepts related to metric spaces and open sets.
winter85
Let X be a metric space with metric d, and let [tex]d_{1}[/tex] be the metric defined by [tex]d_{1}(x,y) = \frac{d(x,y)}{1+d(x,y)}[/tex] . Show that the two metric spaces [tex](X,d)[/tex] and [tex](X,d_{1})[/tex] have precisely the same open sets. Hint: show that they have the same open balls with one exception. What is this exception?
First I note that the function [tex]f(x) = \frac{x}{1+x}[/tex] is continuous and monotically increasing, and that [tex]d_{1}(x,y) < d(x,y)[/tex] for all distinct x and y.
I reasoned like this: Let [tex]S(x)[/tex] be an open ball in [tex](X,d)[/tex] of center x and radius r. Then for all y in S(x), we have [tex]d(x,y) < r[/tex] , therefore [tex]d_{1}(x,y) < \frac{r}{1+r}[/tex] and so y is in an open ball centered at x with radius at most [tex]\frac{r}{1+r}[/tex]. Let S'(x) be the open ball in [tex](X,d_{1})[/tex] centered at x with radius [tex]\frac{r}{1+r}[/tex]. So we have [tex]S(x) \subseteq S'(x)[/tex]
Similarly, for all y in S'(x) we have [tex]d_{1}(x,y) < \frac{r}{1+r}[/tex], so [tex]d(x,y) < r[/tex] hence y in S(x), therefore [tex]S'(x) \subseteq S(x)[/tex]. So we have that S(x) = S'(x) which means the two metric spaces have the same open balls.
It's easy to conclude that the two metric spaces have thus the same open sets, because every open set is the union of open balls.
Now I'm not very sure about this argument, so I hope anyone would point out the weaknesses or points that are wrong or need further justification. Also any hint about what this exception might be?
Thank you.
(minor aside: did you verify that r/(r+1) exists, for all r?)
An oddity about your proof is that you used a different naming scheme for the open balls in (X,d) and (X,d1). (In what follows, I've deliberately chosen different names for my indeterminate variables) In (X,d), you chose a point a and a real number q, and used that to denote the ball
{v | d(q,v) < a}.​
However, in (X,d1), you chose a point c and a real number e, and used that to denote the ball
{w | d(c,w) < e/(e+1)}.​
Any particular reason for doing so? (Was it a conscious decision?) Do you have an argument that all balls in (X,d1) can be named by such a scheme?
I'm sorry but i don't see what you mean by this:
In (X,d), you chose a point a and a Real Number q, and used that to denote the ball
{v | d(q,v) < a}.
in (X,d), i chose a point a and a real number q and denoted the ball
S = {v | d(a,v) < q}. I picked a point v from this set. Then i chose an open ball S' of center a but under the metric d1, that contains the point v. Then I proved that if v' is a point in S', then it must be a point of S also. At least that was my working plan.
for an argument that all balls in (X,d1) can be named by
{w | d(c,w) < e/(e+1)},
e/(e+1) can be any arbitrarily chosen real number in the interval [0,1). the diameter of any set under the d1 metric is in the interval [0,1]. So the radius of any ball in (X,d1) must be in the set [0,1]. If it's less than 1, then it can be represented as e/(e+1) for some real number e. However if it is 1 then it cannot be represented in this way. This would happen when then ball we're considering in (X,d) is the entire set X, and the set X has infinite radius, right? But we know that the set X is an open ball in any metric, it is an open ball in both (X,d) and (X,d1).
I hope now my reasoning is clearer? I'm having trouble organizing my thoughts about this problem :(
  • · Replies 19 ·
