Solving for Spring Compression: A 0.10 kg Wooden Block
The discussion revolves around a physics problem involving a wooden block on a spring, where the block is subjected to a collision with another block dropped from a height. The problem explores concepts of energy conservation and momentum in the context of spring compression.
  • Mixed
  • Participants discuss the application of conservation of energy and momentum to determine the spring compression. There are attempts to set up equations involving potential energy and kinetic energy, with some participants questioning the correct setup and terms used in their equations.
Several participants have offered insights into the problem, with some suggesting methods to find the combined velocity of the blocks and applying conservation principles. There is an ongoing exploration of the correct interpretation of energy terms and the impact of the height from which the block is dropped.
Participants note confusion regarding the potential energy terms and the assumptions made about the system, including whether to consider the height from which the block is dropped or the compression of the spring in their calculations.
BC2210
A 0.10 kg flat wooden block is sitting on a vertical massless spring of spring constant 2000 N/m. An identical block is dropped from a height of 1.00 m above the first block. The collision between the two blocks is perfectly inelastic. How far down is the the spring compressed? Neglect air drag and friction in the spring.
Conservation of Energy? Energy absorbed by spring = (1/2)(kX^2)
Do I need to be concerned with potential energy? So far, I set up the equation:
(1/2)(2000)y2 - (1)(9.8)y + (1)(9.8) = 0 but that didnt give me the correct answer...Im confused as to why!
Any suggestions would be awesome, thanks in advance...
ops...
When the dropped block collides with the stationary block inelastically, find the combined velocity of the blocks by using law of conservation of linear momentum. Now apply the law conservation of energy to find the compression in the spring.
Where does the 1+x come from? Because of the 1m height?
Or was that not correct Bright Wang, I saw you removed it...
Trying out rl.bhat's method now...
ops I was learning conservation of elastic energy in school today.. we never learned momentum in school so I didn't see that...
Ok first you find the velocity of the object 2. (the one that falls 1m). It hits object 1perfectly inelastic, so energy is not conserved but momentum always is!
gh=1/2*v^2
=> 9.8*0.1=1/2*v^2 => v=4.43m/s
Then P=P' => 0.1*4.43=(0.1+0.1)*V
V=2.21m/s
Then use conservation of energy...
1/2*(M1+M2)*V^2+(M1+M2)gh=1/2*k*x^2
then find x
Hope that's right!
Wow that helps out a lot...makes sense:
I came up with:
(1/2)(.2)(2.21) + (.2)(9.8)(1m) = (1/2)(2000)x^2
x = .047m
That look right to you guys? I really appreciate the fast help!
What is this (.2)(9.8)(1m) ?
Combined mass of the 2 blocks * Gravity * The height the block is dropped from...
Or should it not be where the block is dropped from since they are moving as one object now?
Im thinking that's my potential energy (mgy) ?
Or instead of 1m I should have x on that side of the equation?
(1/2)(.2)(2.21) + (.2)(9.8)(x) = (1/2)(2000)x^2
x=.016m
Now it makes sense.
Thanks so much for yalls help...I really appreciate it! It makes sense...
I was able to most all of my HW and get the correct answers but I am not very sure about this last one I did...(Ya know, if you get bored and want to help) :)
A block of mass 1.50 kg is attached to one end of a horizontal spring, the other end of which is fixed to a vertical wall. The spring has a stifffness constant of 2000 N/m. The block slides without friction on a horizontal table, set close to the wall. Find the work done by the spring force if the block moves (a) from the equilibrium position till the spring is stretched by 10.0 cm, (b) from this last position till the sring is compressed by 3.00 cm.
For part A) I said
(1/2)*(2000)*(-.1m)^2
Or should I be looking at integrating from 0 to 10 of the Fspring?
I did it by spring potential = (1/2)(k)(x^2)
