How to Derive the Integral of Sqrt[x^2-a] Using Trigonometric Substitution?
  • Context: Graduate
  • Thread starter Thread starter coverband
    Integrate
The discussion centers around deriving the integral of the expression Sqrt[x^2 - a] using trigonometric substitution. Participants explore various methods and approaches to arrive at the integral without relying on tables.
  • Homework-related
  • One participant proposes that the integral can be expressed as 0.5(x(x^2-a)^0.5) - 0.5aln(x+(x^2-a)^0.5) but seeks a derivation method.
  • Another participant suggests taking the natural logarithm of the expression and applying the chain rule to derive the derivative, leading to a formula for y' in terms of x and the original expression.
  • A later reply expresses frustration over mistakenly taking a derivative instead of focusing on the integral derivation.
  • One participant recommends using trigonometric substitution, specifically mentioning secant and tangent as potential substitutions.
Participants have not reached a consensus on the best method for deriving the integral, and multiple approaches are being discussed without resolution.
Some assumptions regarding the conditions under which the integral is derived may be missing, and the discussion does not clarify the specific values or constraints for 'a' in the expression.
coverband
I believe the answer is 0.5(x(x^2-a)^0.5)-0.5aln(x+(x^2-a)^0.5)
does anyone know how to get this/derive this i.e. not take from tables !
Thanks
I believe what you can do is write out the expression and take the log of both sides. WHen taking the derivative, you must remember y is a function of x.
y = Sqrt[x^2 - a]
y = [x^2 - a]^(1/2)
Take natural log
Ln[y] = Ln{ [x^2 - a]^(1/2) }
Ln[y] = (1/2) Ln{[x^2 - a]}
Take derivative wrt x. Don't forget you must apply chain rule to right hand side. Where y' comes out anyway.
(1/y) (y') = 2x/ (2 (x^2 - a))
writing more neatly, cancel a two
(y'/y) = x / (x^2 - a)
Finally, multiply a y back over and resub your original y.
y' = yx/ (x^2 - a) y = [x^2 - a]^(1/2)
Thus
y' = x [x^2 - a]^(1/2) / (x^2 - a)
y' = x(x^2 - a)^(-1/2)
I'm an idiot, I took a deravitive. Not even the easiest way either.
Use a trigo substitution. Specifically, look at the ones for sec and tan.
