Finding Maclaurin Series Expansions of Functions
The discussion revolves around finding the Maclaurin series expansion for the function F(x) = (1+X^{7})^{-4}. Participants are tasked with determining the first four non-zero terms of the series and evaluating the 21st order derivative at x=0.
  • The original poster attempts to use the known series for 1/(1-X) and substitute X with -X^7, but expresses confusion about how to proceed after that point. Some participants suggest looking for patterns in the series or using derivatives, while others note the complexity of evaluating multiple sums.
Participants are exploring various methods to derive the series expansion, including substitution and brute force multiplication. Some have proposed counting arguments to simplify the process, while others have shared partial results for the first four non-zero terms. There is no explicit consensus on a single approach yet.
Participants mention constraints such as the requirement to find non-zero terms and the complexity of derivatives leading to multiple sums. There is also a reference to external resources for additional questions, indicating a broader context of inquiry.
iceman713
Hey, here's is my problem as the exam states it:
A) Write out the first four non-zero terms of the Maclaurin Series for [tex]F(x) = (1+X^{7})^{-4}[/tex] Give all of the coefficients in exact form, simplified as much as possible.
B) Find the exact value of the 21st order derivative of [tex]F(x) = (1+X^{7})^{-4}[/tex] evaluated at x=0
I can not figure out an efficient(or simple) way to find the expansion of the given function. At first I tried using the known series 1/(1-X) = [tex]\sum X^{n}[/tex]
I replaced X in the equality with -X^7 to get [tex]\sum (-1)^{n}X^{7n}[/tex]
After this though, I'm lost. Apparently I'm not allowed to just multiply the general term by 1/(1+X^7)^3. So I've no idea what to do. :(
Hopefully the solution to A simplifies the solution to B
Did you find the first 4 terms of the MacLaurin series for it yet? The idea is to look for a pattern in those to find the general form of the series.
I tried doing that, the issue I ran into was that the question asks for the first four non-zero terms of the series. I attempted to take a few derivatives, but by the 3rd one I was already dealing with 4 separate sums of functions(that in turn have product rule applied and each become 2 more sums). Not only that, at that point all the terms would have been zeros if they had been evaluated. Seemingly it would take forever to do this the direct method.
I also have another question but don't feel like making another thread for it, I've already typed it up on mathbin:
http://mathbin.net/2926
Take u=X^7. Then 1/(1+u)=(1-u+u^2-u^3+...). To the accuracy you need it 1/(1+u)^4=(1-u+u^2-u^3)^4. You can just brute force multiply it out. Drop any term with a power over u^3. You don't need it. You can also be clever and use counting arguments. For example to get the coefficient of the u^2 term you can either choose one power of u from two of the factors, C(4,2)=6 ways to do that, or one power of u^2 from one of the four factors, C(4,1)=4 ways to do that. So the coefficient of u^2 is 4+6=10.
Yea it does take awhile; it looks like the first 4 non-zero terms are (it takes 21 terms to get them)
[tex]1-4x^7+10x^{14}-20x^{21}[/tex]
That looks like [tex]\sum a_n(-1)^nx^{7n}[/tex]
where the [itex]a_n[/tex] is some sequence that makes the {1,4,10,20,...}; I can't think of what would work for that at the moment though.[/itex]
It's a multinomial expansion. There's probably a concise expression for it somewhere.
  • · Replies 48 ·
