A thrustless propulsion device Help me out
  • Context: Graduate
  • Thread starter Thread starter Anticitizen
    Device Propulsion
The discussion centers on a thrustless propulsion device featuring two skewed rings with spinning balls, originally built by an individual in a garage. The mechanism involved a motorized spinning disc that propelled the balls, creating motion through uneven momentum distribution. Participants clarified that while the term "reactionless propulsion" is incorrect, "thrustless" accurately describes the concept. The consensus emphasizes that such devices exploit static friction and are often categorized as pseudoscience.
  • Understanding of basic physics principles, particularly momentum and friction.
  • Familiarity with mechanical systems and motor functions.
  • Knowledge of propulsion concepts and their classifications.
  • Awareness of pseudoscientific claims in propulsion technology.
  • Research the principles of momentum conservation in mechanical systems.
  • Explore the physics of static friction and its applications in propulsion.
  • Investigate the history and claims surrounding thrustless propulsion devices.
  • Examine scientific critiques of reactionless propulsion theories.
Physics enthusiasts, mechanical engineers, and individuals interested in propulsion technology and its theoretical limitations.
Anticitizen
About a decade or so ago, I came across a website that featured a reactionless drive some guy built in his garage. My google-fu is weak, and I can't seem to find any info on it on the net anymore, and was hoping someone knew something about it. It worked as follows:
There are two rings, set parallel to each other, but skewed slightly. There is a ball (or series of balls) that spin around inside the ring.
Here is my crappy paintbrush representation:
The rig he built had pool balls, I believe, propelled by a motor with a spinning disc located in the center that hit each ball and sent it spinning around the rings at high speed.
(It had another 'retainer ring' to keep the balls from falling out as well.)
He had the whole rig set up on wheels.
There were videos on the site showing the thing scooting across the floor when powered on, dragging an extension cord behind it.
To the best of my memory, this is how it worked:
The ball, when approaching the narrow end of the rings, would spin faster than it would at the other end. Due to some quirk of conservation of momentum, it would carry momentum in that direction (the narrow end) causing the whole rig to move in that direction. Or maybe it moved in the opposite direction, I can't recall.
Does anybody know what I'm talking about, or otherwise can help me address the physics involved here?
There is no such thing as reactionless propulsion. Devices such as the one you mention work by unevenly harnessing static friction and hopping up and down.
Also, reactionless propulsion is a crackpot subject and therefore not something we discuss here.
I shouldn't have said reactionless. Thrustless, as used in the thread topic, was the correct term.
  • · Replies 52 ·
9K
  • · Replies 63 ·
16K
