Archimedes' Principle-Gold Crown problem
  • Thread starter Thread starter mchesypoof
    Archimedes
The problem involves Archimedes' principle in the context of determining the composition of a crown, suspected to be gold-plated lead. The original poster presents measurements of the crown's weight and its apparent weight when submerged in water, along with relevant densities for gold, lead, and water.
  • Participants discuss the calculation of average density and the transition from density percent to mass percent. There are hints about exploring different compositions of gold and lead to identify patterns.
Some participants have offered hints and encouragement, while others are seeking clarification on the calculation of average density and how to derive mass percent from density percent. The discussion is active, with various interpretations being explored.
Participants are working within the constraints of the problem statement, which includes specific density values and the assumption that the crown is composed of gold and lead. There is an emphasis on understanding the relationship between density and mass percent without providing direct solutions.
mchesypoof
You, Archimedes, suspect that the king’s crown is not solid gold but is instead gold-plated lead. To test your theory, you weigh the crown, and find it to weigh 60.0 N, and to have an apparent weight of 55.3 N when it is completely submerged in water. Take the density of gold to be 19300 kg/m3, the density of lead to be 11340 kg/m3, and the density of water to be 1000 kg/m3. Also, use g = 9.8 m/s2
(a) What is the average density of the crown?
(b) What percentage (by weight) of this crown is made of gold? The rest, we assume, is lead.
I found the answer to part a to be 12765kg/m^3, but haven't the slightest idea how to get the mass percent. I found the density percent, but don't know how to get mass percent from this.
Hi mchesypoof! :smile:
Hint: what would the density be if it was half lead and half gold?
if it was 25% lead and 75% gold?
can you see a pattern and a formula? :wink:
Yes! Thank you! It sounds so trivial now, thanks again.
How did you do find the average density? Anyone?
welcome to pf!
hi jimbo14! welcome to pf! :wink:
Show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
