Circular motion (planetary orbit) question
The discussion centers on calculating the new angular velocity of a turntable after two blocks are added. The turntable initially spins at 100 RPM with a mass of 2 kg and a radius of 0.1 meters. The moment of inertia for the turntable is calculated using the formula 0.25 M R^2, yielding an initial angular velocity of 10π/3 rad/s. By applying the conservation of angular momentum, the final angular velocity can be determined after the blocks stick to the turntable.
  • Understanding of angular momentum conservation
  • Familiarity with moment of inertia calculations
  • Knowledge of angular velocity and its conversion from RPM
  • Basic physics principles related to rotational motion
  • Study the conservation of angular momentum in various systems
  • Learn about moment of inertia for different shapes and configurations
  • Explore the relationship between linear and angular velocity
  • Investigate real-world applications of rotational dynamics in engineering
Students studying physics, particularly those focusing on rotational dynamics, as well as educators looking for practical examples of angular momentum conservation.
theneedtoknow
A turntable is spinning at 100 rpms. It has a mass of 2kg and a radius of 0.1 meters. 2 blocks of mass 0.5kg fall simultaneously on 2 opposite ends of a diagonal and manage to stick. What is the new angular velocity of the turntable after the blocks stick?
Moment of inertia of a spinning disk is 0.25 M R^2
Well I know Linear momentum of the ntire system is supposed ot be conserved
Initially its just the table spinning... Linear momentum is L = Iw where I is the moment of inertia and w is the angular velocity.
So Linitial = 0.25 x (2kg) x (0.1m) ^ 2 x winitial
and since it does 100 rpm we can multiply it by 2Pi rads / revolution and again by 1 min / 60 sec and i get 10Pi/3 rad/s
so my L initial is Pi/6
Now since L is conserved, when the 2 blocks fall, the new L should be the same as L initial
the New L will be a combination of the angular mometum of the turntable and of the 2 blocks
so L final = Iwfinal + the linear momentum of the 2 blocks
treating them as point particles of mass 0.5 kg , 0.1m away from the axis of rotation, their individual momentum can be obtained ith the formula L = r x p = r x mv... and v is just wr so it can be simplified to L = wmr^2.. and the w is constrained to be equal to the final w of the turntable
so Lfinal = Ix wfinal + 2mr^2 x wfinal = Pi / 6
(since one is at distance r and the other at -r, but they get squared so it doesn't matter)
From here, I can solve for wfinal and that should give me the angular velocity of the turntable at the end.
I kind of had a question but i think I might have worked it out while typing this up to ask it... but just in case...is this a correct way of approaching these kinds of questions? I've never done anything on angular momentum before and was wondering if this is correct?
BTW don't ask what this has to do with planetary motion c ause it doesn't LOL
Your approach looks correct.
Since Angular Momentum is conserved then
I1ω1 = I2ω2
Where ω = 2πf
