Calculating Mass on a Wave Pulse Along a Wire
  • Thread starter Thread starter 996gt2
    Pulse Wave Wire
The problem involves calculating the mass of an object based on the dynamics of a wave pulse traveling along a steel wire with two hanging masses. The context includes considerations of tension in the wire and the properties of the wave pulse.
  • Participants discuss the calculation of tension in the wire, questioning whether to consider horizontal tension only and how to apply the angle of inclination. There are attempts to clarify the correct expression for tension and its relation to the mass and angle.
The discussion is active, with participants exploring different interpretations of the problem and providing insights into the calculations. Some participants have suggested alternative approaches to finding tension, while others have expressed confusion about the correct application of forces.
There are indications of uncertainty regarding the correct values to use for length and tension, as well as the assumptions about the forces acting on the masses. The original poster has received feedback on their calculations, but no consensus has been reached on the correct method.
996gt2
The figure shows two masses hanging from a steel wire. The mass of the wire is 60.0 g. A wave pulse travels along the wire from point 1 to point 2 in 24.0 ms.
What is mass m?
L=8.0m
[tex]m_{string}=60g=0.06kg[/tex]
[tex] \mu=m_{string}/L=0.0075 kg/m[/tex]
[tex]v=4.0m/24ms=166.667m/s[/tex]
[tex]v=\sqrt{T/\mu}=\sqrt{T/0.0075kg/m}[/tex]
[tex]T=\sqrt{(2mgsin\theta)^2+(2mgcos\theta)^2)[/tex]
Using [tex]\theta=40 degrees[/tex], I got m to be 10.6 kg. However, this answer is wrong. Can anyone tell me where I made the mistake? Thanks!
Aren't you only interested in the horizontal tension in the wire from 1 to 2?
So you mean I should keep using 8.0m for L but use 2mg cos 40 for T?
I tried doing that-->setting 2mg cos 40 for T and then solving for T.
I got 13.9 kg, which is still not right...
Am I supposed to use 4m for L too?
Why is it 2mgCos40 ?
But as to the μ, you simply calculate the density as you did. The density can be considered not to change between the various segments.
Well, I thought that it was 2 mg cos 40 since each of the weights exerts a force of mg cos 40 on the string...if not, I'm confused as to how I should find T
Consider the free body diagram of 1 of the masses in isolation.
Isn't the force of the tension required to hold that mass in equilibrium equal to just mgCos40°?
Ah I figured it out. T=mg/tan(40)...
As I suggested before I think you are only interested in the horizontal Tension between points 1 and 2.
I figured out the correct answer using T=mg/tan(40) so I am pretty sure that is the correct value for the tension in that part :)
996gt2 is right. The answer is 17.8.
  • · Replies 29 ·
