| Thread Closed |
Forces in Equilibrium-Tension Forces at Different Angles |
Share Thread | Thread Tools |
| Dec5-08, 08:55 PM | #1 |
| Dec5-08, 08:56 PM | #2 |
Recognitions:
What you should do is split the tensions into x and y components, can you do that?
EDIT: then use the conditions for equilibrium |
| Dec5-08, 09:23 PM | #3 |
I do not understand the x and y components very well but I guess this might be it:
cos 45° = FT1x/FT1 FT1×cos 45° = FT1x sin 45° = FT1y/FT1 FT1×sin 45° = FT1y ------x---------------y -FT1×cos 45° | FT1×sin 45° FT2×cos 45° | FT2×sin 60° -------------------490N This is more or less how I remember seeing the x and y. I guess then it would be: FT1×sin 45° + FT2×sin 60° - 490N = 0N FT1×sin 45° + FT2×sin 60° = 490N Here is where I get confused on what to do next. I would divide the sin off but then I don't know how to do it so that the FT1 and FT2 are left alone, because I see dividing both sides by sin 45° and sin 60° would get the original sins off the FT1 and FT2, but hen it would be divided by the other sin. What do I do next? |
| Dec6-08, 03:45 PM | #4 |
Recognitions:
Well now you know that the sum of the forces in the y direction is 0 and similarly, the sum in the x is 0 as well.
Now you have T2cos60-T1cos45=0 T2sin60+T1sin45=490 Solve simultaneously now. |
| Dec7-08, 10:31 AM | #5 |
I am having a similar problem. I get to what you said rockfreak on my own, but im not how to go about solving for the separate tension force
I have -T1cos(9.6)+T2cos(17.8)=0 and T1sin(9.6)+T2sin(17.8)-5.5=0 I know that the answers are approximately T1=11.4 and T2=11.8 but I'm not sure how to get those answers. |
| Dec7-08, 11:52 AM | #6 |
Recognitions:
example: 3x+y=4 2x+y=1 can you solve those two? If so, it is the same concept, just calculate the values for the sines and cosines of the angles. |
| Dec7-08, 12:47 PM | #7 |
i would just use substitution. I dont know why i was thinking that i couldn't just evaluate for the values of the sines and cosines. That is where I was stuck. I'll try it. Thanks for the help.
| Dec7-08, 05:08 PM | #8 |
I don't fully understand simultaneous equations either so just to check, I would do this:
Equations: T2cos60-T1cos45=0 T2sin60+T1sin45=490 Works: T2cos60-T1cos45 + T1cos45=0 + T1cos45 --> T2cos60 = T1cos45 T2cos60/cos45= T1cos45/cos45 --> T2cos60/cos45 = T1 By dividing cos60 with cos45, I get 0.707 (sqrt of 0.5) meaning T2×0.5=T1 Substitute T1 with T2×0.5 in T2sin60+T1sin45=490 --> T2sin60+(T2×0.707)sin45=490 T2sin60+(T2×0.707)sin45=490-->T2sin60+T2×0.5=490 Then sin60 is about 0.866, so I assumed that the first term is 0.866th of T2 and the second term is half of T2. Adding them together (0.866 + 0.5 = 1.366) gets T2×1.366 = 490 I assumed that its safe to divide both sides by 1.366, resulting in T2 = 358.7N. Working the same way for T1, I would get 253.64N. (edited from 346.48N) I think did something wrong there. Edit: Wrong output for T1 before edit. Now it looks correct. At least, the numbers substituting the equation for T1 and T2 would result in 490. |
| Dec7-08, 05:19 PM | #9 |
Recognitions:
Your value for T2=358.7N is correct. Put that back into the first equation to find T1.
| Dec7-08, 05:40 PM | #10 |
The equations works out so thank you for your help.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Forces in Equilibrium-Tension Forces at Different Angles
| Three forces in Equilibrium. Find the angles. | Introductory Physics Homework | 0 | ||
| Capillary forces, intermolecular forces and surface tension questions | Classical Physics | 2 | ||
| Tension Forces at Equilibrium Problem | Introductory Physics Homework | 9 | ||
| Forces, velocities, and angles... | Introductory Physics Homework | 15 | ||
| Forces and angles | Introductory Physics Homework | 5 | ||
