Independence of Random Variables
The discussion revolves around the independence of discrete random variables X and Y, where Y is defined as the square of X. The original poster presents a probability mass function for X and seeks to determine if X and Y are independent by using definitions and theorems related to joint and marginal distributions.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the need to calculate the marginal distribution pY and the joint distribution pX,Y to assess independence. Questions arise about how to derive the joint mass function from the marginal mass functions.
Some participants have begun calculating pY for specific values and are exploring the implications of these calculations on the independence of X and Y. There is recognition that finding a single case where the joint distribution does not factorize would suffice to demonstrate dependence. Multiple interpretations of the joint distribution are being explored, but no consensus has been reached.
Participants note the absence of certain probability values and express uncertainty about how to proceed with the calculations. There is an acknowledgment that the probability for some cases may be zero, which adds complexity to the analysis.
kingwinner
Suppose X is a discrete random variable with probability mass function
pX(x)=1/5, if x=-2,-1,0,1,2
pX(x)=0, otherwise
Let Y=X2. Are X and Y independent? Prove using definitions and theorems.
The random variables X and Y are independent <=> pX,Y(x,y)=pX(x)pY(y) for ALL x,y E R
But the trouble here is that we don't have pX,Y(x,y) and pY(y). What can we do?
Thanks for any help!
You will first have to ccalculate pY and pX,Y.
For example
[tex] p_Y(1)=P(Y=1)=P(X=1\vee X=-1)=P(X=1)+P(X=-1)=1/5+1/5=2/5[/tex]
IN the same way calculate pY(y) for the remaining values in the range of Y, and similarly for pX,Y. Of course you would suspect X and Y not to be independent, so it would suffice to find one case where the joint distribution does not factorize.
How can I find the joint mass function pX,Y from their marginal mass functions?
[tex] p_{X,Y}(1,2)=P(X=1\vee Y=2)=P(X=1\vee X^2=2)...?[/tex]
Which X values contribute to this probabbility. They should be such that X=1 and X^2=2:smile:
How is this possible? Is the probability 0?
What other cases do I have to do?
Yes, the prob. is zero. Either do all remaining cases or just compare
[tex] p_{X,Y}(1,2)=0[/tex]
to
[tex] p_{X}(1)p_{Y}(2)=?[/tex]
